Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 13th December 2010, 11:03 PM   #41
markaudio's Avatar
Originally Posted by Bill poster View Post
Thanks very much. This is the ideal scenario.
Was going to mount the 2 FR's in a cab with 2 chambers above a separate enclosure for the SDX7.
Inductors- no idea the value but will work it out.
Nice ideal for the drivers. Try to keep the edge of the frames of the Alps between 8mm to 10mm apart. Better if you can mount them closer together.
For XO of 200Hz, I'd start somewhere around the 5mH value. Quite large so you might need 2 inductors. If you XO at 400Hz, then you're looking at a value around 2.5mH. Much better and cheaper. 400Hz is nice, easy for the SDX7 and just outside the BT 400-4kHz band.
You might want to consider the Alp6P's if you're looking for a "brighter" detailed sound in the mids and highs. Might be a nice tonal combo with the SDX. Give them 2.6 litres each (sealed), this should get you going.
Alp6M smooth sounding, more relaxed. Could be a jazz lovers choice.
Very much a case of personal choice between the 6M and 6P in this instance.
Must dash, packing to do.
Cheers
Mark.
Old 14th December 2010, 04:33 AM   #42
EUVL is offline EUVL  Europe
Mark (F),
Have talked to Jan. Pls check your PM.
Patrick
Old 15th December 2010, 12:16 AM   #43
markaudio's Avatar
Originally Posted by EUVL View Post
Mark (F),
Patrick
Hi Patrick,
At HK airport now. Pls let Jan know I'll email when I get back from Auss - many thanks
Mark
Old 22nd December 2010, 12:24 AM   #44
wushuliu's Avatar
Does the 6M have more of a 'bsc' hump in the 200-400hz range than the Gen1?
Old 22nd December 2010, 03:55 PM   #45
Scottmoose's Avatar
Yes, a bit.
Old 23rd December 2010, 08:06 PM   #46
wushuliu's Avatar
Originally Posted by Scottmoose View Post
Yes, a bit.
Thanks Scott. I've got the 6Ms on the way. I will FAST them with a Minidsp. I was going to just put them in as small an enclosure as I could since I'm crossing to ~250hz or so, but I keep reading how important it is to prevent any reflections from rear wave. Is there a recommended depth if I run them sealed?
Old 23rd December 2010, 09:02 PM   #47
frugal-phile(tm)
planet10's Avatar
If you want to provide any airload on the A6m the box will need to be <~6L. Some load will provide some reduction in excursion at low frequencies. Volumes above 6 litres start to approach infinite baffle response.
Sims have response & volumes for (top to bottom) Q=.707, 0.58. 0.5 and then 10, 20, 50 litres respectively
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th December 2010, 02:20 PM   #48
Musik007's Avatar
These are new arrival of Pensil 6 cabinets. They are made with oakwood.
Old 29th December 2010, 02:34 PM   #49
_henry_ is offline _henry_  Australia
beautiful
Old 22nd January 2011, 10:49 PM   #50
wushuliu's Avatar
If 6Ms are being crossed over at 250hz or higher, does this significantly increase the break-in time?
Alpair 6P Gen. 2 (paper) introduction markaudio Markaudio 30 21st August 2013 03:59 AM
Alpair 6 - Gen 2. - Prototype 1 markaudio Markaudio 53 11th November 2010 04:18 AM
Alpair 12 - Gen 2 otto88 Markaudio 2 30th September 2010 04:06 PM
alpair 6 + 10 gen 2, availiable Monday norman bates Full Range 2 18th September 2010 09:46 AM
When is the alpair 10 gen 2 coming out ? norman bates Markaudio 10 1st March 2010 10:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
