Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 12th November 2010, 08:22 PM   #21
frugal-phile(tm)
planet10's Avatar
Originally Posted by EUVL View Post
Wonder what Mark has to say about the volume ??
Having simmed some of Mark's BR designs i would guess that it would fall in his (and many others) comfort zone.
Do keep in mind that i am very picky, generally not a big BR fan, and all my designs target a very specific shape of curve* and then further mutate the response further by using ports that push the ports into a state that standard wisdom say should be avoided.This has proven time after time to give a finese to the bass that most BR miss.
*(all those alignment type checkboxes are an onselte artifact when calcs were done with pencil on paper & filter shapes of already well-know characters were the target)
As Olson said: "the ear is the final arbiter".
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th November 2010, 08:29 PM   #22
EUVL is offline EUVL  Europe
I am an amp man and not a speaker man.
So if Mark has an idea which is easy to test, then we are happy to oblige.
In any case we are still very happy with our AP6.1M, as "kitchen radio set".
Patrick
Old 12th November 2010, 08:46 PM   #23
frugal-phile(tm)
planet10's Avatar
Based on differences between A10 & A10.2 i expect A6M to, at a minimum -- have better downward dynamic range and a better top in end . I think you'll like them.
dave
Old 12th November 2010, 10:18 PM   #24
markaudio's Avatar
Hi Patrick,
Apologies, from my memory (bearing in mind I'm no longer a young fella) I thought your cab Vol was around 4 litres. Your's and Dave's sims still look makable for 6M in 6.3 litres. Given the relative easy power-train compliance and long'ish excursion of both drivers, I'd say its best to use the sims as starting guides rather than absolute design tools and experiment.
I think MarkL still has cabs in HK? I'd love to hear them in the Chai Wan studio. We can switch the drivers and listen, he can report back to this thread and then possibly send the 6M's onwards?
I've been using those little 3.6L black BR boxes (do you remember them?) in the Chai Wan studio, swopping 6P and 6M regularly. The 6M does sound the more "bass rich" of the drivers in this size. This leads me to suspect the sims may not always accurate predict driver behaviour.
It was my intension to lower the total Q and Fo on the 6M making it more desirable for desk-top and near-field use, where smaller volumes are desired. But it won't surprise me to see 6M in bigger boxes as many DIY folks extract excellent results from Alpairs and CHR's with nice box designs.
Cheers
Mark.
Old 13th November 2010, 03:13 AM   #25
MarkL still has cabs in HK, but you also have one, our very first.
Anyhow, MarkL will bring a pair to you soon.
It is also not totally impossible to reduce volume.
But let's see first.
Can't wait to see your test results,
Patrick
PS Will see Jan on 25 Nov.
Old 15th November 2010, 09:43 AM   #26
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
the 6.3 liter with the 150mm port (Dave's sim) looks like a pleasant sounding bass, this "droop" below 100Hz usually sounds OK (as it is in e.g. my Black Beauty and it is in the Alpair6 Needle)
Old 15th November 2010, 05:37 PM   #27
150mm port should be no problem.
We'll see how the test at Mark's pend out .
Patrick
Old 18th November 2010, 02:06 PM   #28
Bill poster's Avatar
Great looking little speaker- I take it you can use them without a crossover etc
wd like to see them in an active baby TL with ipod dock
Old 18th November 2010, 10:03 PM   #29
markaudio's Avatar
Originally Posted by Bill poster View Post
Great looking little speaker- I take it you can use them without a crossover etc. Wd like to see them in an active baby TL with ipod dock
Hi B,
Yes, something like a ported/vented 3.5 litre box would do a nice job, mini-TL etc. etc. You've got the idea.....
Cheers
Mark.
Old 23rd November 2010, 08:55 PM   #30
Henkjan's Avatar
any news?
Alpair 6P Gen. 2 (paper) introduction markaudio Markaudio 30 21st August 2013 03:59 AM
Alpair 6 - Gen 2. - Prototype 1 markaudio Markaudio 53 11th November 2010 04:18 AM
Alpair 12 - Gen 2 otto88 Markaudio 2 30th September 2010 04:06 PM
alpair 6 + 10 gen 2, availiable Monday norman bates Full Range 2 18th September 2010 09:46 AM
When is the alpair 10 gen 2 coming out ? norman bates Markaudio 10 1st March 2010 10:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
