| Markaudio Designers and builders of audiophile grade drivers |
Mark,
Thanks, Ramon |
#2 |
frugal-phile(tm)
Somewhere recently i just commented on the same inquiry... instead of typing it over i'll just point you to that comment.
Note that if it were me, i'd find a way to afford the Alpair 7. It is a ground-breaking FR driver (along with A12). A true 9 octave capable driver with no audible faults. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Yes
A friend suggested I put this question to Mark. I appreciate your interest and respect your opinion Dave. I believe I am likely going to order the Alpair 7 today, but let me ask you this Dave, is there a new Alpair 7 that is slightly different in high frequency reproduction? And if so is that unit available in the states? Ramon |
#4 |
frugal-phile(tm)
There is an early version of the A7 and a new version. The ONLY difference between the 2 is the gasket. For the new version, Mark has come up with an absoulutely brilliant built-in gasket that completely redefines state of the art.
The A7s that Bob at CSS & that Madisound just received are all the new version (the 1st batch sold out so quickly you'd have to search hard, and get lucky to find a pair of the old ones) dave
#5 |
Is there any audible difference between the two? Don't mean to be obsessive compulsive about this so please forgive my curiosity.
Ramon |
#6 |
frugal-phile(tm)
Maybe, Because the new gasket is injected into the cavities on the back of the bezel, it is a bit stiffer & a bit better damped. Whether that makes a significant difference once the driver is clamped to a baffle is questionable, but it never hurts and gives peace of mind.
As i said, given that being able to find ones without the super-gasket is highly unlikely, you are stuck with the newer ones that come with dave dave
#7 |
Thanks Dave,
I will give the new one a shot and report back on how they sound with vintage restored Altec 416 drivers in an OB configuration. Ramon |
| Desktop XL - a compact TL for the CSS EL70 | Henkjan | Full Range | 35 | 10th July 2010 04:50 PM |
| Introducing The new CSS EL70 | CSS/XBL | CSS | 41 | 19th April 2010 09:23 PM |
| Thirlmere Bipole using the CSS EL70 | italynstylion | CSS | 1 | 8th September 2009 07:39 AM |
| WTB: Stereo Reciever, Plate Amp, CSS FR125S | Evazan | Swap Meet | 9 | 28th September 2006 04:35 AM |
| Page generated in 0.09754 seconds (81.35% PHP - 18.65% MySQL) with 10 queries |
