The future for driver data - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 1st March 2010, 06:38 AM   #11
Hi Mark
I think I sent already this answer but I cannot see it, strange.
Any way, what I'd like to see at least is the frequency resoponse graph to the 0 deg, 20 deg and 60deg angels. Please not smooth the graps too much.
The off axis responses tells much about the element capability to work in normal room with reflections. The most important thing is that the off axis radiation is smooth. It probably slopes down with frequency but it should not have huge drops or peaks.
Non smoothed response tells about the actual quality of the element. If there are narrow peaks it is sign about the resonances. Very raw looking graph on upper freq. range tells much how clear the sound could be.
It may be risk to publish responses but note that most of the elements are used by DIYers and when we anyway measure the elements and publish results in foorums around the globe.
In the full range elements there are always "errors" in the responce but what kind of and where is the key. For example, many Seas Excel series elements have terrible response but they are still good and valued elements.
Old 1st March 2010, 07:18 AM   #12
markaudio's Avatar
Hi Electron,
I moved yours and my posts to the Tweeter thread:
Mark's proto 6.5" Woofer, 1" silk Tweet combo
Thx
Mark.
Old 2nd March 2010, 06:16 AM   #13
Originally Posted by markaudio View Post
Hi Electron,
Thx
Mark.
Hi Mark
All the time I wrote about the the biggest Alpair full range speaker not about tweeter. I used "tweeter" term as tweeter range (5k-20k).
Old 2nd March 2010, 07:40 AM   #14
markaudio's Avatar
Hi Electron,
Arrrrh...... now I understand. I was confused by the use of the word "tweeter".
Yes agreed, it's important to have more data for the better drivers. I've just received the independent review of the Alp12 in Japan's MJ magazine. It's helped me because I'm flat out getting ready for new production.
I'll do my best to publish soonest possible. There's allot of data including off-axis (from my memory).
Cheers
Mark.
Old 3rd March 2010, 07:22 AM   #15
Hi Electron,
It was my fault. I used wrong wording, sorry.
Hmm... new production... sounds interesting Are there any changes in models or do you mean pure manufacturing?
Btw, one interesting driver (also from business point of view) could be tweeter with integrated waveguide just like new Seas models. The tweeter integration to mid range driver is difficult if just trying to fit 1" done and 6" mid. It just does no work in normal room without waveguide. THe tweeter radiates to too wide angle on the xover region compared to mid driver (no matter what is selected xover frequency. This leads to typical 80's desing error where powere response has wide peak on lower treble and if side walls are closer than 2m the sound will be hard and metallic no matter what you do. This often happens on presens range and then it also destroys the accuracy in the sound field as well as it makes the frequency responce on the listening position +-10db zik-zak on that range and even worse the spectrum of first arriving sound is totally different than when the reflections from walls arrives and corrupts the sounds.
This is btw, one reason why full rangers sound so good. There is no stupid design fault in off axes radiation.
The wide and soft wave guide solves the problem plus it adjust the the time difference between mid and tweeter. (which is another reason why full rangers sound so good.)
Old 3rd March 2010, 09:34 PM   #16
markaudio's Avatar
Hi Electron,
Here's the off-axis graphs from the Alpair 12 review in MJ Magazine in Japan. Its interesting to note the off axis comparison between the Diatone P-610 driver and the Alpair 12.
The off axis results for the Alpair 12 are very encouraging. There's allot of flexibility with Alp12 driver allowing users to "tune" the high range either by filter or by arranging the axis of choice by positioning the cabinets. I usually set my Alpair 12 cabs around 10 degrees off-axis to maintain the highs all the way to 20-kHz.
I like to take this opportunity to thank MJ Magazine and Ozawa Takahisa San for granting permission for the use of this data, and for the publication of an English version of their Alpair 12 test review. We hope to complete the translation in the next month. It's challenging to find a translator with enough technical knowledge to cope with the terms in the review. Copyright of the graphs and PDF page belongs to MJ magazine.
Cheers
Mark.
which Mark Audio driver for future project, And WHY? mondogenerator Multi-Way 15 14th January 2010 05:57 AM
confused about driver data MaVo Multi-Way 1 5th August 2008 06:14 PM
The future of Internet speed and data transfer Netlist Everything Else 3 3rd January 2007 12:42 AM
Does anyone know this ribbon driver?? I need some data on it. please!!! sonnya Multi-Way 18 23rd July 2003 03:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
