New 2" (50-mm) Prototype - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 12th January 2010, 10:22 AM   #11
Have you considered offering your drivers in 600 ohm versions like Phillips did 50 years
ago? If Phillips could wind a 600ohm voice coil 50 years ago how hard could it be now with better materials?
Old 12th January 2010, 11:08 AM   #12
norman bates's Avatar
Perhaps the 50mm could have a tiny frame being something along the lines of the bandors or the tiny jordans (meant to be used in a vertical array of 4 drivers).
A climbing response will off set the combing when used that way.
Here is (was) the 7ths veil "nonsuch 4" using 4 of the 50mm bandors.
/images/SeventhVeil_Nonsuch4_big.jpg
but 4 drivers times 13cm2 has about the same cone area as a 4" driver.
Norman
Old 12th January 2010, 11:09 AM   #13
markaudio's Avatar
Hi Tinitus
Errrrrr No: High sensitivity in a tiny driver and power handling is conflicting by the nature of physics. Granted lower sensitivity only offers partial control but anyone who's uses smaller higher sensitivity drivers will just how just how vulnerable they are to being over-driven.
I'm always try not to comment on other maker's drivers products, so I'll do my best to talk technical observational terms only. I'm won't comment on what I think of these driver's performance qualities on their published data.
Looking at the examples you've suggested, Tymphany's unit, its T/S have similarities to the Alpair 5. Don't be confused by their quoted power ratings. This has more to do with durability testing than actual usable power. Tangband's power rating is nearer to what could be termed as "usable" and trade's away Fo at 160Hz and Xmax @ 1-mm. None of these units gets so close to the Fo-100-Hz 90dB dream. Both these drivers, along with mine face the same laws of physics. There's no free lunch.
I know you mean well but I have been building drivers for many years now.
Mark.
Last edited by markaudio; 12th January 2010 at 11:26 AM. Reason: Adding member name
Old 12th January 2010, 11:09 AM   #14
Sin Bin
Hi, since this is the manufacturers forum, not the fullrange, I feel perfectly
confortable speaking about tweeters. (Markaudio is offering a dome unit if I'm not wrong.)
In my opinion, a quality paper cone unit, with easy flange, like was the Peerless CT62H,
will be welcome from more than one, and no one is offering such a thing nowadays...
Old 12th January 2010, 11:13 AM   #15
markaudio's Avatar
Hi Woody,
Interesting idea. I re-worked the coil on the 6.5 woofer with regard to some of your thinking. Ummmmph, would it be practical? I'll leave to others to comment more on this.
Cheers
Mark.
Old 12th January 2010, 11:17 AM   #16
markaudio's Avatar
Norman
Hello Norman,
Nicely thought out.
I'm already looking into finding a square frame. But is there enough demand? ummmmph - got to earn a crust.
Cheers
Mark.
Old 12th January 2010, 11:22 AM   #17
markaudio's Avatar
Hi M,
Good point - well spotted! Now you can possibly guess where I may be sort of heading............... so to speak. But can I eek out more range! That's my nature.
Cheers
Mark.
Old 12th January 2010, 11:24 AM   #18
markaudio's Avatar
Guys,
I gotta go get some more driver work done. It's 7.30 P.M in HK, still much to do.
Mark
Old 12th January 2010, 09:43 PM   #19
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by tinitus View Post
Maybe a thicker poleplate would help?
With a narrowed thickness at gap, fore a longer overhung voicecoil
Or, thick poleplate edge/gap fore a short underhung voicecoil
And maybe neomagnet
Inside/outside winded voicecoil might help too
Hi Mark
Since you commented on the least essential parts of my post, I think you may have misunderstood my intentions
Maybe I should have limited my post to the above
Anyway, isnt sensitivity very much about bandwidth, and frequency
Regarding powerhandling
Many very small dome tweeters can have quite high powerhandling
Why cant any other driver have that too
I suppose its about materials and heat transfer
Old 12th January 2010, 10:27 PM   #20
frugal-phile(tm)
planet10's Avatar
Originally Posted by markaudio View Post
Yep, Fo @ 100Hz is the target - well done!
90dB...... arrrrgh more difficult. At 90dB, power handling will be Zilch, distortion a real danger. It needs to take at the least a 1.5 watt load, so something in the low to middle 80's is safe.
Just as a reference, what i consider the market leader currently in this segment, has an Fs ~125 Hz and efficiency of ~86-87 dB.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Class A heat - "pull my finger" is 50 not 60 lgreen Construction Tips 4 17th October 2009 12:13 AM
crate vintage "club 50" schematics needed cbriere Tubes / Valves 2 14th November 2007 07:39 PM
Decent, smallish (6" maximum, 4 or 5" preferred) fullranger below US$50? ux226 Full Range 5 5th March 2007 04:58 PM
D.I.Y. "Duplex" 2sk369 jfet mm phono preamp doggy Analogue Source 6 26th September 2006 09:23 AM
Old Jordan 50 mm modules mick Full Range 0 7th December 2003 09:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
