Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 17th September 2010, 11:05 PM   #91
markaudio's Avatar
Hi Guys,
Here we go. Kick off for the final assembly of Alpair 10 commences this Monday 20th September. Should complete with the week.
Will try to post activity reports from the Mat Corp factory.
Cheers
Mark.
Old 25th September 2010, 09:55 PM   #92
markaudio's Avatar
Hi Guys,
We're almost finished. Apologies for not posting reports to date. it's been a very hectic week. We've had just about every challenge thrown at us including errant glue machines, power cuts and a flood to name a few. Anyway, its Sunday so we're final prepping all the drivers and packing today. They should ship out to Hong Kong docks this Wednesday, onwards to dealers from there.
Taniguchi san has been taking many photos so I'll post some of his in the week. I'm going to try to make a short video showing what's new. I'll attempt to do this soonest possible.
Not sure if its better to start a new thread?
Cheers
Mark.
Old 26th September 2010, 11:21 PM   #93
dwb2 is offline dwb2  United States
Default Alpair 10 availability
Sounds good Mark!
Ever since I overloaded my pair of gen1s I have been waiting for the gen2s. What do you think availability will be in the US?
Also, BTW, after some over-zealous rocking out by my good wife (my fault that they we not properly installed yet and didn't warn her) I noticed that my 10s had developed a series of radial ruptures aroung the edges of the cones. I thought they would be unplayable, BUT for the most part they still sound good. Distortion is only noticeable at higher SPLs and at certain frequencies. Hard to say how this may be effecting their overall performance, but even with this significant amount of damage they do real well.
Cheers!
Old 28th September 2010, 07:22 AM   #94
markaudio's Avatar
Originally Posted by dwb2 View Post
Sounds good Mark!
Cheers!
Hi Dw,
Gen 2 CHR's are already in the US. Give Madisound a call:
https://www.madisound.com/store/prod...oducts_id=8860
https://www.madisound.com/store/prod...oducts_id=8859
Cheers
Mark
Old 28th September 2010, 07:30 PM   #95
mp9 is offline mp9
Is the Silbury still suited for the A10 Gen II, also wrt "modest", what are the minimum room size and listening distance's?
Old 29th September 2010, 03:25 AM   #96
norman bates's Avatar
Post #63, is that the freq response measured infinite baffle ?
Does bass climb, that would make baffle step easier do deal with ?
If it is (as it is on that post), we could get away with a box face barely large enough for the driver (least until 300hz).
Could we see an Impedance plot ?
I'm itching to put one in an open baffle, acually an open backed box.
Same dimensions as mjk and his lowther, 2' wide x 4' tall x 1' deep, covering inside walls with foam and maybe 3" foam covering the back. Centered, it should go flat in room to close to 150hz (Feq around 180hz, no baffle step needed). Maybe cover the front baffle (facing us) with thick foam also, that is an aweful large reflective surface.
Norman
Old 30th September 2010, 12:55 PM   #97
otto88's Avatar
Originally Posted by planet10 View Post
Nothing wrong with a FAST. (i'm working on an A7 + 4 7" per side, XO 125-250 Hz). Releiving the FR of bass duty sweetens the mids as well as giving a really solid bass foundation.
A small sealed box will give a 2nd order rolloff but i don't think you can get one small enuff to get it up to 500 Hz -- and a box that small could really congest the mids. It will also have a big bump just above roll-off.
For instance A7 in a sealed Q=0.707 box (13.5 litre) has an F3 of 85 Hz. Then a 1st order PLLXO could be added at the same frequency to give a 3rd order roll-off.
2 litre gives a Q-1.215 with about a 3dB bump at ~150 Hz. One could put an XO (for practical purposes way better to be active) up higher than this and roll off the bump up.
if you want to XO that high (i'd suggest crossing lower) you will need filters.
dave
Sorry, I dont follow: what is a FAST; and why an "A7 + 4 7 inch" per side: are the 4 * 7" for the bass, wired in eg series - parallel?
Old 30th September 2010, 01:29 PM   #98
otto88's Avatar
I found out that FAST = fullrange assisted by subwoofer technology . .
and the 4 * 7"? Two 7 inchers a side, in series - parallel?
Old 30th September 2010, 04:07 PM   #99
frugal-phile(tm)
planet10's Avatar
4 7" per side, in an arrangement similar to the KEF Blade. This project is meant to be a statement kind of thing ... something you'd find at the local hifi emprioum for well in excess of $10k
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd October 2010, 12:40 AM   #100
otto88's Avatar
Would be a statement alright.
There are 4 a side in Joe Rassmesssun's Elsinore, in series - parallel
Is that how you intend wiring them?
Alpair 10 Bass + Alpair 5 - Woodwill Japan markaudio Markaudio 16 26th January 2010 11:48 AM
Alpair 10 and 5 Combination _henry_ Full Range 19 1st June 2009 08:24 PM
alpair 10 box width ? norman bates Full Range 9 15th May 2009 03:54 AM
Alpair 10 Measured T/S Parameters MJK Full Range 12 30th March 2009 06:04 PM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 11:37 AM
Copyright ©1999-2013 diyAudio
