Pensil 12 and B&W Matrix 802 - Page 7 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 4th August 2010, 06:15 PM   #61
glt is offline glt  United States
Ah yes. I was referring to the fact that from the picture, it seems relatively easy to build. Certainly care in building is required. I've seen the equipment at Home Depot. The rip fence seems accurate enough so that if you set it and don't move it, all rips would be of equal size. The radial arm saw for the crosscuts seems also very high end. I intend to tell the person at Home Depot to be more careful when setting up the cuts. Truing the panels at home is not possible, as all I have is a jigsaw :-)
www.hifiduino.wordpress.com
Old 4th August 2010, 06:18 PM   #62
Scottmoose's Avatar
They're fine for the precision that's normally expected of them. I believe most people find they need to true panels cut by such equipment. You don't even have a plane and a straight edge?
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 13th August 2010, 07:21 PM   #63
hemanth is offline hemanth  India
Originally Posted by Scottmoose View Post
Basically, the larger cabinet has another ~10Hz on the bottom end.
Does this mean that we will get less bass out of Super Pensil 12 when compared to Pensil 12?
Old 13th August 2010, 11:14 PM   #64
Scottmoose's Avatar
No, it means it goes ~10Hz lower.
Old 19th August 2010, 06:19 AM   #65
neutron7's Avatar
That looks very good!. what is the volume of the sealed box, if you do not mind me asking.
Old 26th April 2011, 05:31 AM   #66
skeeter99's Avatar
Originally Posted by norman bates View Post
I'd rather run A12 pencils all the way around. That way you can easily swap them if damaged, blown, etc. It would be hard to make a center channel pencil for the 12, but I think it is possible, assuming you can have a seperate large shelf for a maybe squarish 2' x 2' box (I could) .....
Norman
Have there been any other center designs for the A12 besides the sealed version listed in this thread? I'm with Norman, I can fit a big center to get the lower tuning. My current is 36" W and I like the "looks" of having a big center
Scott
Pensil Series for Mark Audio Drivers planet10 Markaudio 46 28th September 2011 08:19 PM
Internal mods on B&W 802 Matrix? Jai Multi-Way 5 18th May 2004 07:16 PM
Seeking kit or design for amp to drive B&W Nautilus 802 geof Solid State 3 28th October 2003 02:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
