Mark's proto 6.5" Woofer, 1" silk Tweet combo - Page 6 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 8th January 2010, 03:55 AM   #51
markaudio's Avatar
Hi Guys,
Here's the pic of the latest version of the woofer. The T/S, Frequency and Impedance data was posted just before Christmas (24 Dec.) on this thread.
A few changes:
1 - Minor cone modification to further flatten the response and a change of colour from white to black.
2 - Front suspension modification, mainly to do with extending durability.
3 - 4 layer coil (already mentioned in the 24 Dec.) post.
4 - Front looks improved. Together with the Hex screws (these come with the drivers), the seal is also improved. The idea being to give the driver a "pro" look if you chose to front mount the unit.
Hope you like it!
Cheers
Mark.
Old 8th January 2010, 04:21 AM   #52
gooki is offline gooki  New Zealand
Looks good.
Old 8th January 2010, 11:43 AM   #53
DYNABLASTERTUNERS's Avatar
exactly my taste, simple but great Design and it looks noble!
some of my Designs www.dynablaster.deviantart.com/gallery
Old 8th January 2010, 07:02 PM   #54
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
Hi Mark,
I was doing a few quick simulations with your driver data and it looks good for a box of about 14L with a mild peak in the bass for both a closed box and a vented box. However one thing that would help with the simulations would be the hight of the voice coil and the hight of the gap. Is this data available?
Also how were your graphs obtained are they 2Pi or on IEC baffle (or some other method) ?
Many thanks,
Andrew
Old 11th January 2010, 04:03 AM   #55
markaudio's Avatar
Hi Andy,
Yep, the likely volumes will be 14 to 22 litres depending on the trade-offs between range and power handing.
I think you need the Xmax (1 way) = 5.75-mm
Testing is anechoic in chamber, LMS-v4 on IEC baffle
Mark.
Old 11th January 2010, 06:55 AM   #56
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Looking good Mark, I really like the changes where the frame meets the surround! I think I liked the white cone better, but that's probably just me.
Nice and healthy xmax too...
The power of Science compels you!
Old 11th January 2010, 04:32 PM   #57
markaudio's Avatar
Hi Dcibel,
Many thanks for your encouragement.
Ummmph, I quite like the white cone also. But the general comment is its gotta B "Black". I guess its a "man" thing. Wonder if we can attract some nice ladies into the hobby?
Cracking good comment on Amp hum! I wonder if I can teach my 300B to sing in harmony?
Cheers
Mark.
Old 11th January 2010, 05:05 PM   #58
tresch is offline tresch  United States
I'm also down with the white cone. Something different!
then again I like the black one, too...
Maybe an option in the future?
Old 11th January 2010, 11:18 PM   #59
gfiandy's Avatar
Hi Mark,
As an exercise, I did some simulations using the FRD tools of the effect on freq response of a IEC baffle.
The frequency response disturbance between 1K and 2K could be diffractions from the edge of the baffle and possibley the dip at 650Hz. Depending on the exact size and placement of the driver in the baffle.
I assumed the dimensions from the FRD web site -
135,165cm rectangle 22.5 and 15cm offset from center.
It matches more closely if you didn't quite get the offset right. However that could just be a simulation error. See JPG.
Thought you might be interested as you don't want to try to engineer out a frequency disturbance that is a diffraction error.
Andrew
Old 11th January 2010, 11:25 PM   #60
frugal-phile(tm)
planet10's Avatar
I like white paper cones tooo... i can make them any colour i want when i go at them
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Anyone tried "hello proto" PCB service? neutron7 Parts 20 30th December 2006 05:01 PM
6.5" silver flute with 1 1/8" dayton silk dome tweeter jadenlinkletter Multi-Way 10 28th February 2006 08:20 AM
Anyone design a system with the Dynavox 28mm tweet and 6.5" woofer? JCoffey Multi-Way 0 21st April 2005 03:26 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 03:29 AM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 06:36 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
