#21 |
Hi H,
I've got a series of projects in progress (too many really). Here's pics of Tweeter No 1 and woofer No 10. For the woofs I'm sort of going on size, No.6 is 6", No 10 is 10"(25-cm) and so on but naming is not fixed as yet. Cheers Mark |
#22 |
Hi PeteMcK,
Thanks for your input. Along with some direct email feedback, the thinking is the Total Q of the 6.5" woof is too high. For guys wanting large sealed boxes (60 litres up) it's potentially a nice driver. But for most applications, the larger box volumes aren't practical. Suggestions I'm getting are in the region of 0.4 to 0.6 for the Qts. This should allow the driver to operate more effectively in vented or sealed volumes in the range of 14 to 30 litres. Please feel free to feedback on parameters. This is the time when I change the design of the components and do some tweaking. The challenge is to make changes without adding cost........ummmmmph. Cheers, Mark. |
#23 |
wow, that blue is so nice
#24 |
More work on the Woofer. After some tweaking, here's the latest set of parameters. Briefly, Qts is reduced to 0.37. Resonance frequency is lowered to 40-Hz, Vas is up to +30 litres. SPL is also increased to 88dB. This should make the driver more practical for most box designs.
I only had 4 Ohm coils in stock so hope to wind a 6 Ohm unit next week. Comments appreciated Revc= 3.600 Ohm Fo= 39.534 Hz Sd= 12.868K mm Vas= 30.033 Ltr Cms= 1.277 mm/N Mmd= 11.849 g Mms= 12.688 g BL= 4.960 T Qms= 1.818 Qes= 0.461 Qts= 0.368 Levc= 223.069u H No= 0.400 % SPLo= 87.919 dB Cheers, Mark. |
#25 |
Hi Guys,
The woofer's performance has been revised, see details on this thread: Mark's proto 6.5" Woofer, 1" silk Tweet combo suggestions and comments appreciated. Thanks Mark. |
#26 |
The drivers have a lot of potential if you can get the prices right (i.e. low).
I'm always on the look out for a low cost woofer tweeter combo to recommend to friends who want to get into DIY, but don't want to spend a lot on raw driver and then screw it up. And at the same time want something of quality that will work with various crossover and enclosure designs. PS I'm not a fan of the cone/dustcap colour vatiation. I'd personally prefer all black cones or possibly your trademark copper/gold colour (which works well contrasted to a black tweeter). Last edited by gooki; 25th November 2009 at 08:13 PM. |
#27 | |
Hi Mark, isn't that total Q rather high for a bass reflex? Sorry, i'm assuming that's what you mean by "BR" box. Only reason i ask is that in effect the amplifier needs more control over the cone than it would in a sealed box (where the box can help control the cone motion). You have gotten me interested as i happen to have some (what i regard as high Q) bass drivers that are of a similar Q to yours. Admittedly these haven't been run in so the Q may lower & VAS increase, however they are still a nightmare in a reflex enclosure Transient response suffers & damping from the amplifier is less than with a low QTS driver, i'd expect the things (mine) to have a rather boomy & uncontrolled bass. Perhaps i'm missing something? Please feel free to fill me in & this post is in no way meant to p*ss on your fire so to speak Another Mark.
"Never let your morals prevent you from doing what is right!" Salvor Hardin Last edited by event horizon; 25th November 2009 at 08:37 PM. Reason: added value |
#28 |
Hi Mark (another),
How's like in UK? Many thanks for your suggestions. Agreed, I over cooked the Qts in the first proto. Thinking guys like to build big boxes but times are changing. Did you the end of the thread? I've changed the driver's damping and coil to get these results: Revc= 3.600 Ohm Fo= 39.534 Hz Sd= 12.868K mm Vas= 30.033 Ltr Cms= 1.277 mm/N Mmd= 11.849 g Mms= 12.688 g BL= 4.960 T Qms= 1.818 Qes= 0.461 Qts= 0.368 Levc= 223.069u H No= 0.400 % SPLo= 87.919 dB Might be interesting to produce two driver types - high Q for those who want to make a large classic sealed, lower Q for BR's and alike. Ummmmph...... will be be enough demand for both types? Cheers, Mark (HK) |
#29 |
Hi Gooki,
Thanks for comments. Agreed, my thinking also. Basically, I'm attempting to make: 1 - a low cost woof-tweet combination 2 - with a wide near flat combined frequency range 3 - easy to design a cross 4 - and various box type friendly I know there's allot of drivers out there but I'd lke to have a go because many guys know me for my work on full range. I enjoy tweaking drivers to extract extra performance. Re cone colours, I'm thinking of offering 2 colour choices, including an all-black cone/cap. Cheers, Mark. |
#30 |
This looks quite interesting. I understand that the tweeter is to come in around USD$10, do you have an expected price (or range) for the woofer?
I really like the look of the woofer, apart from the frame, specifically where the frame meets the driver surround. This ends up not looking very attractive when mounting the driver on the front of the baffle, and I'm not really a fan of mounting on the back side of the baffle, but if the price is right it may be a worthwhile compromise.
The power of Science compels you! |
| Thread Tools | Search this Thread |
| Anyone tried "hello proto" PCB service? | neutron7 | Parts | 20 | 30th December 2006 05:01 PM |
| 6.5" silver flute with 1 1/8" dayton silk dome tweeter | jadenlinkletter | Multi-Way | 10 | 28th February 2006 08:20 AM |
| Anyone design a system with the Dynavox 28mm tweet and 6.5" woofer? | JCoffey | Multi-Way | 0 | 21st April 2005 03:26 PM |
| WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer | gengis | Swap Meet | 0 | 17th March 2005 03:29 AM |
| Dayton 6" reference and dayton silk dome tweeter combo project...input? | nerd of nerds | Multi-Way | 4 | 2nd December 2004 06:36 PM |
| Page generated in 0.14330 seconds (80.79% PHP - 19.21% MySQL) with 11 queries |
