Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 16th September 2011, 11:37 AM   #181
The Odd Couple:
Walter M. - It took me three months to realize that F.U. on all of your notes stood for Felix Unger!
You guys remind me of this scene.
Old 19th September 2011, 03:16 PM   #182
Originally Posted by markaudio View Post
Revc= 7.000 Ohm
Fo= 35.391 Hz
Sd= 12.668 K mm
Vas= 25.737 Ltr
Cms= 1.129m M/N
Mmd= 17.086 g
Mms= 17.906 g
BL= 7.093 Tm
Qms= 2.183
Qes= 0.554
Qts= 0.442
Levc= 619.309u H
No= 0.199 %
SPLo= 86.010 dB
Hey Mark,
are this the final Parameters of the Woofer No. 6? I just bought a pair of those in Europe, Germany. The local distributor provide some different data:
Fs 39,51Hz
Re 7,5 Ohm
Vas 34,50 l.
Qes 0,456
Qms 2,9509
Qts 0,395
Sd 137 cm²
Mms 12,29 g
SPL 88,71 dB
BxL 7,0858
Did the european market receive different samples?
With kind regards, Alex
Old 19th September 2011, 08:38 PM   #183
markaudio's Avatar
Originally Posted by AlexGER View Post
Hey Mark,
Fs 39,51Hz
Re 7,5 Ohm
Vas 34,50 l.
Qes 0,456
Qms 2,9509
Qts 0,395
Sd 137 cm²
Mms 12,29 g
SPL 88,71 dB
BxL 7,0858
Hello Alex,
I think you bought the drivers from Blue Planet Acoustic? They do their own testing which is NOT anechoic, publishing their own data without any consultation with me. I recommend you follow my anechoic LMS data.
Blue Planet Acoustic are no longer my main dealer for Europe.
Many thanks
Mark.
Old 19th September 2011, 09:45 PM   #184
Hello Alex,
Many thanks
Mark.
Hello Mark,
thank you for the reply.
I didnt buy them at the shop you mentioned, but I know they have/had such woofers...However, I'am going to use your data. (Btw, what do you think about a closed box design with a lift in the low frequences via DSP ?!)
Why ? Send me an PM if necessary.
Old 19th September 2011, 10:32 PM   #185
markaudio's Avatar
Hello Mark,
Hi Alex,
Thanks for your support. I think the re-seller that sold you the No.6 woofs will have been supplied from Blue Planet, your re-seller using their data.
I've enjoyed my time with Nick and Thorsten at Blue Planet. They are nice guys but Markaudio is growing; Its time to take a fresh look at how Europe Diyers are best supported and supplied. See this thread:
European Distribution - your opinions, ideas
Mark.
Old 19th September 2011, 10:48 PM   #186
Hi Alex,
Mark.
Thank you,
I'll have a look at the thread
Regards, Alex
Old 22nd September 2011, 10:53 PM   #187
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
or you could put them in a smallish closed box (qb=0.9) and add a 470µF series capacitor
Old 22nd September 2011, 11:12 PM   #188
norman bates's Avatar
Hello everyone, I just quickly flipped through the last 10 or so pages.
Is there a first order design idea yet using a tweet and woofer ?
Norman
Old 24th October 2011, 12:08 PM   #189
jimbro is offline jimbro  United States
I second that question. (el166 and ert26)
Old 16th November 2011, 08:00 AM   #190
Toppsy is offline Toppsy  United Kingdom
Well here are a couple of my 2-way designs using the Woofer #6 (EL166) and Tweeter #3 (ERT26) and using a first order crossover. The second larger floorstander using 4-woofers started life using the T#3 but with the gain in SPL of the 4 series/parallel wired woofers raising to 93dB/94dB it was just a little too much to ask of the excellent 1" silk dome tweeter. So I now use the Monacor ribbon tweeter. The midrange from the floorstanders has been favourably likened to that of my Quad63 ESLs. A testament to Marks design of the woofer.
These drivers are excellent performers as a simple 2-way speaker.
Anyone tried "hello proto" PCB service? neutron7 Parts 20 30th December 2006 04:01 PM
6.5" silver flute with 1 1/8" dayton silk dome tweeter jadenlinkletter Multi-Way 10 28th February 2006 07:20 AM
Anyone design a system with the Dynavox 28mm tweet and 6.5" woofer? JCoffey Multi-Way 0 21st April 2005 02:26 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
Page generated in 0.11917 seconds (83.06% PHP - 16.94% MySQL) with 11 queries
