| Markaudio Designers and builders of audiophile grade drivers |
#11 |
This is the one we listened to at Mark Fenlon's last October :
ALPAIR10¤È5¤Î2¥¦¥§¥¤ - Linfof¹©Ë¼ - Yahoo!¥Ö¥í¥° http://blogs.yahoo.co.jp/linfof/fold...html?m=lc&p=19 Patrick Last edited by EUVL; 23rd January 2010 at 11:12 AM. |
#12 |
I initially typed in 1-2 kHz, but then I wanted to provoke some discussions, so I changed it to 2-3 kHz.
300Hz is for me too low. The overlapping region is not large enough for the AP5 using first order HP. Patrick |
#13 |
#14 | ||
If you want to make the filter less complex, I see 2 approaches:
btw: here's the cover of the HH: ![]() BT made a nice round cabinet for the Alpairs |
#15 |
I was thinking of Jim's Jordan Mini Monitor with Ribbon. Seems to be very nice speaker, except the crossover is not phase coherent. Using a AP5 as tweeter would solve that.
The discussion whether to cross at 1kHz or below or whether at 3kHz or above is more like whether the 10 or the 5 should be used as the "full range" (or main speaker). I tend to favour the 10, if only for less distortion at somewhat higher SPL. But I guess the only way to find out is to build and listen. What is your opinion, Mark F ? Patrick |
#16 |
"I was thinking of Jim's Jordan Mini Monitor with Ribbon. Seems to be very nice speaker, except the crossover is not phase coherent. Using a AP5 as tweeter would solve that".
Hi Patrick, Personally, I'm not a big fan of adding tweets to Full Range drivers that can get to 20-kHz @-3dB or so from their SPL. The Alpair 7 certainly does away with the need for a tweet. Adding a tweet to this driver would be sacrilege. But we live in changing times and guys are adding tweets. If I were to add a tweet, I'd cross above the 4-kHz telephonic threshold, thus utilising what should be the better low to mid emitting performance of the full-ranger. It also explains why I've been a busy fella tweaking the my new 6.5 woof and tweet to emit flat response so they too can be crossed higher. A reasonable rule from British Tele-communications (Scott Moose knows more on this) is to cross below 400Hz or above 4000-kHz. I understand their the outcome from years of communications practice is: Don't mess around with the in between frequencies. Having said this, for many applications it may not practical to cross so low or high. Niwa san in Japan has done some very nice work in BR's with Alp10-Bass and Alp5 crossing at around 1.5-kHz (from memory) with first order. Certainly, from what I've heard from his sample system in our studio, there's a "seamless" quality to his work that many two-way's don't achieve. Also, many woofs aren't capable of being crossed high, say above 2.5 or 3-kHz. So cross point choices are limited in many cases. Cheers Mark. Last edited by markaudio; 26th January 2010 at 09:27 AM. Reason: Additional info. |
#17 |
Hi Henkjan,
I'd like to take this opportunity to personally thank you for your design efforts for the Alpair series drivers. You've produced some great designs and helped many new Diyers gain pleasure in the making of their build projects. These contributions and your new ideas are welcomed. Thanks Mark. |
| Alpair 6 Bass Reflex Bookshelf | EUVL | Full Range | 61 | 7th October 2010 08:29 AM |
| Alpair 7 - out of the bag | markaudio | Full Range | 16 | 27th November 2009 12:30 PM |
| Alpair 12 - also out of the bag | markaudio | Full Range | 23 | 23rd November 2009 03:48 AM |
| Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 11:37 AM |
| Can anyone help TL or ML-TL for Alpair 10 | _henry_ | Full Range | 3 | 31st December 2008 06:31 AM |
| Page generated in 0.11219 seconds (83.30% PHP - 16.70% MySQL) with 10 queries |
