#61 |
Here's a pic of Mark Fenlon and Tadashi Matsubara San discussing the rear suspension set-up on the Alpair 12. A VERY interesting conversation.
There's also an interesting link to Norio Nakajima san's blog. Its in Japanese, worth using Google or similar to translate. Also some interesting links on this site fidelitatem sound Last edited by markaudio; 28th October 2009 at 04:12 PM. |
#62 |
just received the new Alpair 12. Looks nice! ![]() ![]() I am preparing a loudspeaker für the Hifi Music World in Germany if anyone is interested in listening the Alpair 12. ![]() Harry |
#63 |
Hi Guys,
Running in method for Alpair 7 and Alpair 12 As you may have read in the main thread, the suspensions on both the 7 and 12 are special designs. The rear suspensions in particular require careful use during the running-in period. Please proceed as follows: 1 - Use music only, No artificially generated signal of any kind. 2 - Don't press down on the cone. This action risk's physical distortion of the power-train. Alpair 12 First 20 hours - low listening volumes, Xmax not to exceed 2-mm. Play vocals, stay away from heavy bass music. Hours 21 to 120 - gradually increase to middle listening volumes. Xmax not to exceed 4-mm. Gradually introduce rhythmic music with some bass. Alpair 7 First 20 hours - low listening volumes, Xmax not to exceed 1.5-mm. Play vocals, stay away from heavy bass music. Hours 21 to 120 - gradually increase to middle listening volumes. Xmax not to exceed 3-mm. Gradually introduce rhythmic music with some bass Patience will deliver musical rewards! Cheers, Mark. Running In- Alpair 7 and 12 |
#64 | |
#65 | |
Hi Mark,
![]() Some of that can be nastier (to the suspension I mean) than a 15Hz "breaking in" sine often used for speakers. Cheers! |
#66 |
Hi Geek,
Go easy during the run-in period. It's not good to over-stress most any driver during the first 100 hours or more depending on the design. In the case of the spider, the material needs time to reach its optimal stroke length. Re all types of music, the Alpair 12 is capable of playing any music once it's run in. Then it's all about your set-up, room etc. I've got a pair playing loud (doesn't take much to get them performing) but like most big full rangers, they are best driven at moderate to normal listening levels. For big amp, play it loud, rock and roll guys, multi-way is the better bet. Mark. |
#67 |
Will the Alpair 12 be good for OB ???
#68 |
Are there any experiences with A12 in horns yet?
#69 |
Designed but not built.
Avebury from Woden Design. Scott is looking for one or more serious beta testers. ![]() dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#70 | ||
| Thread Tools | Search this Thread |
| Mark Audio Alpair 10 MLTL Design | Jim Griffin | Full Range | 199 | Yesterday 04:56 PM |
| Jordan JX92S from EAD or Mark Audio Alpair 10? | ilwooz | Full Range | 56 | 20th March 2010 02:26 AM |
| Mark Audio Alpair 5/CSS SDX7 DIY | Chris74 | Swap Meet | 4 | 17th February 2009 03:44 PM |
| Page generated in 0.11403 seconds (87.84% PHP - 12.16% MySQL) with 11 queries |
