Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 25th June 2010, 03:37 AM   #61
Musik007's Avatar
Hi dave,
What is the sensitivity of CHR-70 in your nMarS70?
Is there any sealed cabinet designed for Alpair 7?
Thanks,
Tony.
Old 25th June 2010, 06:06 AM   #62
frugal-phile(tm)
planet10's Avatar
Sensitivity is the same as any other single driver CHR box (excluding front loaded horns)
A7, if it can be fit (we continue to lobby for no decorative bezel), works in the same sealed box.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th June 2010, 06:45 AM   #63
chrisb is offline chrisb  Canada
dave
driver cutout, particularly if rebated for flush mounting is different (note decorative bezel is just under 10mm thick)
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 25th June 2010, 06:50 AM   #64
frugal-phile(tm)
planet10's Avatar
As is the driver brace...
dave
Old 28th July 2010, 03:36 AM   #65
type is offline type  United States
How long does the CHR-70 (2010) take to burn in?
Old 28th July 2010, 03:59 AM   #66
frugal-phile(tm)
planet10's Avatar
Quite a while. By 100-200 Hrs it should be thru the worst of it.
dave
Old 28th July 2010, 04:31 AM   #67
dave
That's good to hear. I wasn't aware these little guys took so many hours. I was starting to doubt all the positive feedback on them - figured I'd post the question here first before jumping to any conclusions
Old 2nd February 2011, 08:32 PM   #68
johancraftech's Avatar
Can anyone assist with the exact dimensions for the Needle Deluxe (designed by Thorsten Fischer) for the Markaudio CHR-70. The drawing I have lack some dimensions (refer attached pdf). Thanks
Old 3rd February 2011, 01:44 PM   #69
Thumbs up NEEDLE DELUXE
Kindly ignore my request - the copyright holder provided me with the detail provided I don't publish it and/or use it for commercial purposes.
Page generated in 0.09547 seconds (76.29% PHP - 23.71% MySQL) with 10 queries
