Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 19th December 2009, 09:46 PM   #21
markaudio's Avatar
Hi Mike,
Glad the drivers arrived OK. You may have the first generation CHR drivers. There's some technical and performance differences between the first and second generation CHR-70 drivers. As this thread is made for information exchange on the second generation, please make use the main application thread:
Mark Audio CHR-70 Application Thread
We are gradually up-grading our website. This webpage may useful for DIYers who want to know more about the differences between the model generations.
CHR-70 Full Range Audio Driver (Nov 2009 Revision) | Markaudio
If you want to also post on this thread, please remind folks which generation of driver model you have. This helps to avoid any confusion.
Many thanks and Merry Christmas
Mark.
Old 19th December 2009, 10:34 PM   #22
Thanks Mark, So if I didn't get mounting screws I have the old version right?
mike
If We The People refuse to hear the truth we will be ruled by liars.
Old 21st December 2009, 12:02 AM   #23
markaudio's Avatar
Hi Mike,
Yes, the first generation don't have screws inside the box. Also, the gold and grey colours are darker than the second generation. I'll try to find time over the Christmas break to post a pic showing the visual differences.
Cheers
Mark.
Old 28th December 2009, 08:07 PM   #24
Hi All,
merry xmas
it's look like new CHR70 has worst performance in highest frequencies (above 15kHz)
cheers
vlado
Old 28th December 2009, 08:50 PM   #25
jolltec is offline jolltec  Germany
hello Mark,
I´m planning to built speakers with the new CHR-70.
Blue Planet Acoustic in Germany has a construction based on the popular "needle" Needle DeLuxe - Lautsprecher Selbstbau by blue planet acoustic and those who built this version are very happy.
Nevertheless I like the Pensil design very much.
If you know their version - which are the differences between the Pensil and the Needle de Luxe? Which is the better speaker in your opinion?
Kindly regards and best wishes for the new year
Jörg
Old 28th December 2009, 09:18 PM   #26
frugal-phile(tm)
planet10's Avatar
Do you have a link that takes one to plans for the Needle Deluxe?
I have plans for the new Pensil for the revised CHR-70. Just OKed by Scott, need to just tidy them up a bit.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th December 2009, 09:29 PM   #27
frugal-phile(tm)
planet10's Avatar
vlado,
I'm not sure where you are getting that from... it starts falling off above 20 kHz (the graphs go to 30k). I've seen 1" dome tweeters without as extended or as smooth on-axis response.
Now it is true that on-axis response tells us only about the on-axis performance, and little about the overall driver performance.
dave
Old 28th December 2009, 09:46 PM   #28
Scottmoose's Avatar
And just to point out (again) that like is not being compared with like. The MK1 CHR70 response graph has considerably more smoothing applied.
Old 28th December 2009, 11:03 PM   #29
dave
click the link I have given and then click the green button (middle right)
Old 28th December 2009, 11:42 PM   #30
frugal-phile(tm)
planet10's Avatar
Looks like a pretty standard, guess & by golly, Voigt pipe. I don't trust those until i've seen what they model like in MJK's sheets
dave
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
