Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 9th January 2006, 03:06 PM   #1
Send a message via MSN to skullkeeper Send a message via Yahoo to skullkeeper
Default 400 w ushio centering?
just a quick ? on the ushio bulb do i center the middl of the grape shaped thing with the center of my lcd or do's the center of the outer glass of bulb with lcd center
Old 9th January 2006, 04:22 PM   #2
good question, i'd like to know too.
Old 9th January 2006, 07:42 PM   #3
i think i got it man check this thread out http://www.diyprojectorcompany.com/p...ighlight=ushio
Old 10th January 2006, 03:15 AM   #4
cool.
good find man.
i'm just waiting on lcd panel thing to be worked out, maybe in a week i'll be ready to start assembling.
Old 10th January 2006, 03:23 AM   #5
i just got done marking my wood for the lcd its all ready to be cut out now. pluss i had to add a inch on my wood hight i was a bit short when i had lows cut it sence my masurments was for 1/2" thick mdf and all they hadd was 3/4" thick so i had to do quick adjustment in my head for them to cut. gota love liqued nail.
Old 1st February 2006, 10:59 PM   #6
does anyone know if a reflector and condensor are needed for one of the ushio bulbs and a 15" screen?
15.4" eMachines LCD(1024 x 768)
3M 9700 OHP Optics in custom enclosure
2 Fan Cooling Setup
Works Great!
Old 1st February 2006, 11:01 PM   #7
a reflector yes condencer no
Old 1st February 2006, 11:25 PM   #8
ok, thanks...
i had a core/coil ballast and one of the huge globe bulbs and was having problems with an even light and such, i just got an electronic ballast for cheap and ordered a ushio bulb, so i'm going to work on a newer nicer enclosure with this new setup
2 Fan Cooling Setup
Works Great!
Old 2nd February 2006, 12:28 AM   #9
Are you sure a reflector's needed? I mean, I've heard most reflectors only add about 30% more brightness. I've also heard the ushio is plenty bright without. But for all I know, you're right. Just asking.
Old 2nd February 2006, 12:35 AM   #10
v1d9uy is offline v1d9uy
so far no matter what bulb yer useing you can always use more light .... so 30% is alot
Thread Tools
Self-centering Magnetic Suspension? Stocker Everything Else 5 8th February 2006 01:56 PM
centering hub for cdpro skyraider Digital Source 0 1st July 2005 08:08 AM
NAD 7020, problem with tuner++ (centering). hanspd Solid State 0 26th January 2004 02:37 PM
Centering cone during surround replacement Kanga Multi-Way 20 31st May 2003 05:43 PM
Page generated in 0.18304992 seconds (82.77% PHP - 17.23% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
