Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 14th December 2005, 04:10 PM   #1
Default Tell me the pros and cons of using quartz filament
ok, i'm building a box projector as soon as i get the nec 1530v that i won on ebay.
I already have a brand new never used Dukane Starfie 4030 so i was thinking about using the quarz filament 410 watt bulb, reflectors, fresnel, etc. from this high quality overhead.
my question, Tell me the pros and cons of this lighting source, (will i notice a better color temp if i get the sodium ballas and ushio lamps that you guys are using alot? does the quartz filament burn hotter so it will be harder to cooL?
one thing i'm not liking is the heaviness i hear about the magnetic ballast if i go with the one you are using...
Old 14th December 2005, 04:51 PM   #2
v1d9uy is offline v1d9uy
the bulb in the OHP will give a yellowish picture and will be hott along with not being all that bright. now you could use the fresnel but it will not be the opimum size for a 15inch lcd so you will not get the brightest image with the small fresnel. the only thing that i would use is the lense i dont know if youres is a doublet or a triplet but iether way it will be "ok" to use for starters. and on the bulb again they do not last that long ... and have a high price for how long they last. with the ballast wieght should really not be a big deal .. unless yer gunna hang the PJ and even then .... just make sure you do a good job hanging it and you should be fine ... but i dont recomend hanging it.
Old 14th December 2005, 05:19 PM   #3
my fresnel from the Dukane starfire 4030 is 12 inches by 12 inches.
so i think that's big enough. (i know most ohp aperatures or 9.5 or so inches but this one is pretty big once you remove the plastic that overhangs... or take out the lense)
but i jut realized the mirror inside the dukane i was gonna salvage might be too small. then again, it works for the large ohp, maybe if the mirror is close it is big enough?
Old 14th December 2005, 06:23 PM   #4
hey, while we are on the subject.
if metal halide is trually that much better, (i do know the differences as i used to run reef aquariums)
but what is in those expensive store bought lcd projectors? those are too small to have a metal halide in them.. like the sharp models you see in the universities... (now i have to admit usually the room has to be real dark to get awesome results.)
i'm just saying the color temperature is maybe not as good at the ushio, but they can be very close, but yes, they do burn out fast, buy i found a replacement lampf for my starfire 4030 for only 7 bucks with shipping.
Old 14th December 2005, 06:32 PM   #5
ya know im not sure but i think there halogon also but ..... again the price plus the how long they last ... suck i mean its up to you as far as halogon vs metal halide goes ...you know the diff MH is brighter lasts alot longer and has a better color to it but cost about 3-4 times a cheap halolon, but lasts 10x as long. ill admit if i didnt find that cheap ballast on ebay and got that retro MH ushio bulb id be useing halogon for a long time. i got my OHP from a college surplus store for $10 and paid $11 for a bulb locally ... bam dun.... just add lcd that costed me $120. i did spend $90 on a sharp qa 1650 that ended up not working right and i got all but my $20 shipping back ... i got it about 95% working but still not good enough to use yet.
Old 16th December 2005, 03:59 AM   #6
i found a cheap MH ballast kit here if anyone is interested, they have a company manufacture them for them, it looks good, i got it today and my bulb will be here tomorrow, i will let you guys know how it works
15.4" eMachines LCD(1024 x 768)
3M 9700 OHP Optics in custom enclosure
2 Fan Cooling Setup
Works Great!
Old 16th December 2005, 04:44 AM   #7
cool.
so this ballast runs a regual metal halide? not a sodium one?
what bulb did you order for it? and do you know how much the ballast weighs?
Old 16th December 2005, 04:53 AM   #8
lol all the ballast weigh about the same .. there all heavy that is the best deal iv seen for a normal MH ballast id prolly buy one but im going with that one on ebay for $28
Old 16th December 2005, 01:39 PM   #9
according to UPS tracking the package weighed 15 lbs.
2 Fan Cooling Setup
Works Great!
Thread Tools
Pros and cons of Neodymium magnets weinstro Multi-Way 2 6th August 2007 11:15 PM
pros/cons of a 845 VS 211 jarthel Tubes / Valves 2 18th June 2007 01:57 PM
TL vs MLTL, pros and cons Tomac Multi-Way 5 29th December 2004 01:55 PM
Filterless DAC - pros and cons? mr_push_pull Digital Source 1 11th August 2004 03:56 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 06:37 PM
Page generated in 0.24203205 seconds (77.63% PHP - 22.37% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
