| Lighting and OHP any lighting ideas and ohp info |
#141 |
I can't edit for some reason but I tried the switch again and it worked! your diagram helped me out SOOO Much skull! i'm a fool when it comes to wiring like that, but it made it so much better!
The LED on the Switch still doesn't come on ![]() <shakes fist> |
#142 |
cool im glad you got it going. yea it gets bright i cant wait to get my pj up and going my first one was a psone pj with a ohp bulb and i wasnt happy with brightness sence i could only see it at night in a dark room so 400w should be great. keep us updated on your pj
#143 |
Don't forget that MH lamps put out tons of UV light. (Even the ones that have UV-blocking outer glass still put out a lot.) Even though it looks white, it has enough UV in it to severely damage your eyes or to give you a bad sunburn.
ALWAYS wear UV blocking sunglasses or welder's goggles if you will be looking right at a bare lamp while it is running. If you have to reach into the box to make an adjustment, make it quick or else wear long sleeves and gloves. Even with UV blocking, these lamps are bright enough to leave major blank spots in your vision for a while. It is like staring at the sun! They also get very hot, but you should never touch their glass with your bare hands anyway even if it is cold. Just like halogen lamps, you don't want fingerprints on the surface because that can overheat the glass. Finally, please try not electrocute yourself or your family! Ballasts put out 5000 volt spikes during startup, and then enough power to kill you after that. Get everything insulated and clamped down. If you are not familiar with power wiring, please at least get your work inspected by an electrician or electronics tech. |
#144 |
Hey thanks for the Advice Guy, I never looked into the arcI figured that would be bad, is there any particular way to mound the ballast, Ignitor and Cap?
#145 |
It's up to you. I used some aluminum formed into nice curves and screwed to the box frame, to mount my capacitor and ignitor. (Don't squash them.) I used the metal brackets that came with the ballast to bolt it to my box frame. The ballast is very heavy, so you should think about mounting it in a way that spreads out all that stress (if your box is flimsy), and to keep it low so the box doesn't tend to fall over.
The only other major issue is to shield all of those parts from direct exposure to the lamp light. Don't want to overheat them. |
#146 |
ok guys since eveyplace is back orderd on the UHI-S400DD USHIO
is it the ONLY bulb we can use for this ballast that will work for projection ? i finnaly have the money to order one .. but now i cant get one .. and since i have the ballast im not gunna switch to a regular MH ballast and bulb... im almost just went down to homedepot and got the brightest halogon they had ... and then tried to cool it ... |
#147 |
but it might just be a few weeks for an ushio, sure you don't want to wait?
#148 |
well my prob is i have the money now.. and might not later .. that and the subout on my reciever isnt working ..... so thats driveing my crazy so i want to get a new reciever .... and i have found a few for what im willing to pay...... witch isnt much but if i do that then ill be waiting o n money again to buy the bulb .. when it comes available again.... lets just say i am very impatient.
#149 |
I'm also interested in finding an alternative bulb. It will be more than just a few weeks wait from what I was told, more like a few months. In the meantime I wouldn't mind buying an inferior (hopefully inexpensive) bulb to use with the ballast so I can at least continue the project. Anyone have a suggestion?
#150 |
well i found 2 that i think will work ... but am not sure the only prob is there not that cheap and there color temp is like 2000k
witch from what i know is way to low here is one http://www.topbulb.com/find/Product_...ductID_E_46876 and heres another http://www.1000bulbs.com/product.php?product=27 |
| Any mid priced SE transformers around? | RockysDad | Tubes / Valves | 21 | 21st January 2007 02:25 PM |
| Fluorescent ballasts in SE | Jaime | Tubes / Valves | 1 | 30th January 2006 07:07 PM |
| Need help finding mid priced kit | gompka | Multi-Way | 1 | 30th June 2005 04:24 PM |
| WTB Tonearm. Reasonably Priced. | ramond | Swap Meet | 0 | 12th July 2004 04:08 AM |
| Page generated in 0.10428 seconds (77.00% PHP - 23.00% MySQL) with 11 queries |
