Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Lighting and OHP any lighting ideas and ohp info
Old 7th December 2005, 02:07 AM   #21
Mark Techer's Avatar
Send a message via ICQ to Mark Techer
indeed carbon arc was used for projection. The projectionist probably went blind from continually adjusting the electrodes.
I knew a few projectionists that worked with carbon arc. They all used a welding mask
http://www.hometheaterdiscussion.com...80&postcount=9
This is a short story I originally posted at HTD when I was researching the DIY Anamorphic lens...which has been a huge success by the way...
Mark
CIH Explained
Old 7th December 2005, 02:11 AM   #22
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
Default Somewhat related...
The same basic principal was used in spotlights for many years. Heck, a lot of arenas and large concert halls still use carbon arc spots. We have 6 Strand Troopers in my hometown and they are big, heavy, and dirty behemoths. Running a carbon arc light is an art form in itself, and the number of people that can run one well is diminishing quickly.
Btw, a small window with #10 welding glass is on the side of the lamphouse to allow viewing of the arc without damaging the eyes.
Old 7th December 2005, 02:19 AM   #23
Exactly what the projectors (I talk about in the link) had...
though during opperation, if there was anything that needed to be checked, the projectionist would open the side (couldn't shut the arc down whilst the movie was running) and out came the welding mask and gloves...
Mark
CIH Explained
Old 8th December 2005, 08:20 PM   #24
atrade is offline atrade  United Kingdom
atrade's Avatar
If you do go to the drive in, take as many pics as you can!
Being in the UK, drive-in movie theatres weren't about but always loved to be able to see one!
Grab some pics, and some reels!
Old 9th December 2005, 01:28 AM   #25
Here you go...
http://www.driveinmovie.com/mainmenu.htm
Mark
CIH Explained
Old 6th August 2006, 12:01 AM   #26
jm47 is offline jm47  United States
Mark,
Hard to believe that I just found your link.
This is one forum I don't monitor regularly. I'm going to have to put this on the list.
Anyway, a couple corrections to what you wrote.
Conventional films don't have any squeeze. The are projected what we call "flat".
The old original movies (before the '50s or so) were 1.33:1.
Then came "wide screen" or around 1.66 to 1.85:1
These use conventional lenses.
Scope is 2.35:1 aspect ratio with a 2/1 stretch.
Also, the primary determinant of color from a carbon arc isn't so much the arc gap but the distance from the reflector.
I'd have to check my reference books, to see which direction (too far or too close) from the reflector produced which color. Let me know, and I'll find it for you. The correct distance obviously produced perfect daylight white.
Old 6th August 2006, 06:02 AM   #27
Correct and that is what I meant. The image on the print itself is squeezed, and the lens then stretches out the image to restore the geometry...
I've got some "scope" film here. I might try and see if I can scan and attach the image...
Mark
CIH Explained
Best Movie Per Nielsen Everything Else 40 24th February 2003 08:02 PM
Page generated in 0.08501 seconds (76.53% PHP - 23.47% MySQL) with 10 queries
