| Lighting and OHP any lighting ideas and ohp info |
#41 |
what distance would you need between the lamp and the condensor lens for a 15inch lcd?
#42 |
Hi 18wheeler
H1=18mm,H2=3.3mm,H3=3.2mm |
#43 |
I'd like to get in on this group buy if it would be good with a 15" setup
#44 | |
The original distance between the edge of reflector and the condensor is 48mm. to use with a 220mm F.L. field fresnel, that distance should be shorten to 21mm; with a 330mm F.L. field fresnel, that should be 29mm. it may varies a bit in real life. The fresnel is shown in 15" diagnal
#45 |
When can we start buying them?
#46 |
just jumpin in to say Id like a lamp and ballast
#47 |
18Wheeler,
I'm trying to find out if I can use my IceCap e ballast (for MH lamps) it is 250W at 120V. Do you think it would work? I read the discussion in the other thread about power ratings and such, but I am still unsure. I ask because I foun a single ended MH buld that will work with my ballast ( saving me money to spend on the lamp) with almost the same specs - 250W; arc length-5MM or so; and a life of 2000 hrs; 6500K for about $64 GBP that works out to about $100US. Still, $85 for 2 is not bad. If only I can get it to work.
"It's all Fun-N-Games 'till somebody gets hurt!" |
#48 |
What's the status on this lamp, bulb and ballast? Will it be available for North American voltage?
| [For Sale] 250W Metal Halide Ballast & Lamp | MC | Swap Meet | 6 | 22nd August 2004 04:10 AM |
| Page generated in 0.07531 seconds (79.81% PHP - 20.19% MySQL) with 11 queries |
