Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Lighting and OHP any lighting ideas and ohp info
Old 3rd April 2005, 02:37 PM   #1
Default difference between T and TS?
Whats the difference between OSRAM POWERSTAR HQI-T 250W DAYLIGHT and OSRAM POWERSTAR HQI-TS 250W DAYLIGHT?
what does the T and TS mean. Also where can I find out the dimensions of these bulbs. I've checked out the osram sight already.
Old 3rd April 2005, 04:38 PM   #2
Me2! is offline Me2!  Canada
Me2!'s Avatar
T means Daylight (from the German - Tageslicht)
S means Shielded (UV barrier)
Old 3rd April 2005, 05:35 PM   #3
thanks for that reply. What is daylight then?
Old 3rd April 2005, 10:53 PM   #4
Me2!'s Avatar
Daylight refers to the temperature. Usually a 500k to 6500k lamp is daylight.
Goto the osram or ge-lighting websites for detailed explanations of these things.
Old 4th April 2005, 02:48 AM   #5
The upper-tier HQI-TS lamps don't have an external envelope....
Or do you mean UV-coated.
Old 4th April 2005, 06:01 AM   #6
Megaman is offline Megaman  Sweden
Take a look at this: http://www.osram.no/brosjyrer/english/K01KAP5_en.pdf
The -T version is larger and got an E40 socket, -TS is two-sockled.
Both seems to have UV-filter.
Not sure wether daylight means /D, /NDL or /WDL though, that defines the color temperature.
Old 13th April 2005, 04:49 AM   #7
Me2!'s Avatar
Pardon the typo,
Daylight is 5000k (not 500 k lol) to 6500k
The shielding is from the quartz not an additional outer envelope.
D was used for durable hence the T for daylight.
Id select text but the pdf wont allow it - see attached.
This is from an OSRAM document, other manufacturers may use other terms!
Old 13th April 2005, 05:05 AM   #8
Me2!'s Avatar
the screenshot was too big. heres the jpg
Old 13th April 2005, 10:58 AM   #9
ace3000_1's Avatar
Send a message via Yahoo to ace3000_1
D= 5000k - 5800k Daylight
NDL = 4000k - 4800k Newtral or near daylight
WDL = 3000k - 3800k Warm daylight
Trev
"Every technique can be used in a great many ways, but mastering it, thats what realy counts."
What's the difference? squirtacious Tubes / Valves 4 23rd October 2007 04:38 AM
How much difference 0.22 vs 0.33 cap? pengboon Tubes / Valves 1 1st July 2007 10:07 AM
difference between 1 and 2 androtaker56 Car Audio 9 14th November 2005 12:36 PM
What's the difference? 2.83V/1m - 1W/1m 1Time Everything Else 5 10th February 2003 03:54 AM
Page generated in 0.09632 seconds (73.93% PHP - 26.07% MySQL) with 11 queries
