Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 6th February 2005, 04:57 PM   #1
Default Has anyone tried this for lighting?
I did a search and it was way to many threads to read, but I read a few and did not find anything on this subject.
Has anyone tried an automotive headlamp?...and reflector.
The reason I am asking is because I just had to buy one for my wifes car, and a lamp went off in my head.
After all, they are very bright, small, last quite a while...are cheap (about $12 or so) and are made to take much abuse....I never really tested how much heat they put out, but I can't imagine it being too much.
Please give your opinions
Old 7th February 2005, 03:14 AM   #2
Either no one has tried it, or I am an idiot....or both.
;P
Hmmm...I may have to try it.
Old 8th February 2005, 12:51 PM   #3
SOTA is offline SOTA
Then we're both idiots because I was about to say the same thing until I saw you post.
The idea sounds reasonable...bright, self contained, long life and cheap.
Old 9th February 2005, 12:04 AM   #4
I think I will have to try it, the only thing is converting house current to run it.
Does anyone know how to go about that?
Would an automotive headlamp setup run on household current?
I may have to make a trip to the loocal junkyard.
If it's free, it's for me!
Old 9th February 2005, 12:04 AM   #5
Hey SOTA,
Thanks for the reply!
It just may work.
Maybe I'll dissasemble my wifes brand new Honda for testing!
Yea right.....I'd be a dead man.
Old 9th February 2005, 01:15 AM   #6
Stocker is offline Stocker
HID lights would probably be the ticket. Junkyards would be the source. Super bright, tight beam to begin with, BUT the parts new are $$$ from the dealerships. American cars without HID tend to have more of a broad swath of illumination vs. a tight beam straight ahead.
Jesus loves you.
Old 9th February 2005, 05:31 AM   #7
corryn00's Avatar
Send a message via AIM to corryn00 Send a message via MSN to corryn00 Send a message via Yahoo to corryn00
the only problem with car headlights is that normal halogens look yellow and the HID ones look blue... not a good color temp for either i'm afraid
Gordon
BUY FIRST...ASK QUESTIONS LATER!
Old 9th February 2005, 06:16 AM   #8
blue is in the eyes of the beholder. also the oncoming driver but that's another topic...
I have seen some HIDs coming at me that were almost not blue at all. I guess that would be for the projectionist to experiment with.
Jesus loves you.
Old 9th February 2005, 06:40 AM   #9
corryn00's Avatar
i would love to see someone come up with a more cost effective bulb that doesn't require a huge ballast!
Gordon
Old 9th February 2005, 07:38 AM   #10
stick is offline stick
The standard automotive headlighting (not the High Intensity Discharge) is usually halogen, which I have read gives off a more yellowish light as compared to MH lighting. Also, these lights are usually only 65 watts or so, therefore relatively dim. From what I have read, even 100 watts of halogen lighting is far dimmer than 100 watts of MH lighting, so I would expect there would be insufficient light for decent projection.
If you were to try it, however, you would need a power supply capable of about 6 to 8 amps at 12 volts. If it were me, I would stick with whatever you already have, but experimentation is how we all learn, so give it a whirl and let us know.
On the other hand, if you find a wrecked Lexus and beat everybody else to the HID, I think that would make for an interesting experiment - although I wonder how balanced the color spectrum is....
Thread Tools
ATV Lighting WordUpOnLCDs Everything Else 4 30th December 2005 09:17 PM
help with possible lighting mod YonjaminYodle Everything Else 1 16th June 2004 10:17 PM
Page generated in 0.27735496 seconds (46.27% PHP - 53.73% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
