Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Lighting and OHP any lighting ideas and ohp info
Thread Tools
Old 9th February 2005, 04:38 PM   #11
Send a message via MSN to 18wheeler
automotive HID lamps are typically 35W. They are special type of MH, and the light output is similar to a 35W MH. And most DIYers use 250W MHs.
as for color, 5100K retrofit automotive HIDs are available, so it is not a porblem. the problem is that they are not bright enough for LCD projection.
Oh, by the way, the idea was around the forum about 2.5 yr ago and got shot down.
when i think about it, it might be OK for 5" or so LCD (PSone) with large projection lens (CRT) and relatively small projection size ( < 50"? )
Old 9th February 2005, 10:42 PM   #12
Here is a link to some HID specs.
By the way, stick, thanks for the electrical info..it will come in handy.
http://www.hidexpress.com/index.asp?...on=Custom&ID=5
Old 9th February 2005, 10:42 PM   #13
PS - Watch this video...they say that Xenon lamps reproduce almost exactly the color of daylight.
Whether that is good, or bad I'm not sure...I would imagine good.
http://www.hella.com/produktion/Hell...en_xenon_e.mpg
Thread Tools
ATV Lighting WordUpOnLCDs Everything Else 4 30th December 2005 08:17 PM
help with possible lighting mod YonjaminYodle Everything Else 1 16th June 2004 09:17 PM
Page generated in 0.05056691 seconds (71.99% PHP - 28.01% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
