| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Lighting and OHP any lighting ideas and ohp info |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
#21 | |
A pulse start bulb has a high voltage ignitor coil that is used to send high voltage pulses to the bulb to bridge the arc and start the bulb (like a coil and spark plug in a car). |
#22 | |
#23 | |
The starter produces about 2 to 5 kV spikes to ionize the gas in the lamp. The starter normally has a triac across the ballast and a diac trigger cct. When open cct voltage is across the lamp, the diac fires the triac to short the ballast, the triac then opens. This "kick" produces the voltage spike. Once the gas ionizes, the lamp impedance drops then gradually increases as the lamp warms up. The lamp running voltage is about 1/2 of the open cct voltage With the lamp removed and power on, you can normally hear a good starter "ticking". The open cct voltage is stamped on the ballast and is between about 150 and 350 Vac, depending on lamp wattage and ballast. Also, a capacitor is often connected in series with lamp to improve peaking and ballast action. For Probe start your right, but its still a starter, just a diff kind (as i previsly said). No bulb will fire without some kind of starter. Trev
"Every technique can be used in a great many ways, but mastering it, thats what realy counts." |
#24 |
whats will be the diference between a single ended lamp and a double ended lamp?
#25 |
A double ended can only be run in a spherical type of reflector, the single can be run in a parabollic, elliptical or the spherical. Size also, the single ended are smaller.
Trev
#26 |
well it's better than
![]() Did you get my e-mail? let me know thanks |
#27 |
Hmmm no email this way, i sent you one the otherday that was it.
Trev
#28 |
i just sent it again trought the forum. let me know if you receive it this time.
#29 |
oopsquote: The GE has good specs but is a dud @ 200 hrs Ayyy?????? Try 12000hrs. The best 250w to get is a 250w HQI-TSD Trev /Quote Sorry, I think I was looking at the wrong one on the sheet. Ithought you meant this becasue the link came up there: Table 32: Discharge-CSR (Daylight) Metal Halide, Single-Ended Hot Restrike 200 T6 CSR200/SE/HR 14, 63 48462 10 GZY9.5 70 15000 5600 90+ .323 .328 5 200 39 80 Any 50 My mistake. |
| Thread Tools | |
| FS: Quad Sylvania 6L6GB | Zedguy | Swap Meet | 2 | 10th February 2008 01:01 AM |
| JAN Sylvania 7308 vs. JAN Sylvania 6922 | Rodango | Tubes / Valves | 7 | 3rd September 2007 10:39 AM |
| sylvania & GE tubes | airframe | Tubes / Valves | 5 | 31st July 2006 11:31 PM |
| Sylvania News | Bas Horneman | Tubes / Valves | 14 | 25th April 2004 05:42 PM |
| Page generated in 0.26868105 seconds (68.63% PHP - 31.37% MySQL) with 10 queries |
