| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hi there, I have a perfectly spherical ditronic/fs(is that it?) reflector out of a ELMO overhead projector, now they put the bulb arc at roughly 2.5cm away from the reflector rim... but from all the searching I have done, im under the impression that the arc is ideally ment to be mounted basically dead on the rim, even a little bit recessed to get the arc right on the rim(centered) if you know what i mean.
So whats the real freakin deal?
mMmMmmMmmk? |
#2 |
The second way is the correct way. The only reason that people say to put the ark at the rim of the reflector is because they are probably using a soup ladle, which is a half sphere. Most pro reflectors are less, more like quarter spheres.
DJ |
#3 |
i think your reflector is dichroic so dont worry about the heat.
the light is reflected but head (IR) goes throug it. |
#4 |
I agree with Dazzzla. the second way is right. It will avoid 'two light sources' as you realized.
don't use a soup ladle unless you cannot find a feal reflector. |
#5 |
what do you use to make a surface more reflective?
if i had a spherical surface, what could i do to make it like a mirror? |
#6 | |
Trev
"Every technique can be used in a great many ways, but mastering it, thats what realy counts." |
#7 |
interesting,
it affords heat? (afford?? ) como se dice mejor esto?
#8 | |
Trev
#9 |
its a coated reflector, whats the best thing to clean it with? something non abrasive im guessing?
and is there an easy to determine the focal point?
mMmMmmMmmk? |
#10 | |
The easiest way to find the R1 focal is to set somthing in the middle of the sphere until its reflected the same size, in other words the object reflected you shouldnt see any bigger or smaller then the actual object. Trev
| Thread Tools | |
| Fostex HP reflectors | no xo | Full Range | 28 | 21st December 2006 04:02 PM |
| HP Sound Reflectors | tenderland | Full Range | 3 | 30th December 2005 02:19 AM |
| Page generated in 0.17816710 seconds (77.46% PHP - 22.54% MySQL) with 11 queries |
