Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Lighting and OHP any lighting ideas and ohp info
Old 1st March 2005, 03:21 PM   #11
Default Re: my cooldown timer
Originally posted by rth
In this case, the 2200 uF and 43 Kohm combo yields a 3 minute 5 second discharge time, so the fan will run for this amount of time after shutoff. Raising either the cap value or the resistor value will yield a longer cooldown period, if required. Vice versa is also true.
Don't you mean raising either the cap value or lowering the resistor value will yield a longer cooldown period?
Old 1st March 2005, 05:23 PM   #12
rth is offline rth  United States
rth's Avatar
Default Re: Re: my cooldown timer
No sirree, bob. A lower resistor value will yield a higher discharge current, which yields a quicker discharge and shorter fan run time.
construction is done!
Old 1st March 2005, 05:38 PM   #13
Sorry - I don't know what I was thinking (actually I was still thinking backwards until I thought about a short or open circuit as the resistor)!
Old 2nd March 2005, 01:45 AM   #14
Guy Grotke's Avatar
Default One thing left to turn off!
Now if it could just turn off the +12 power supply, then it would be perfect!
Old 2nd March 2005, 04:45 AM   #15
Stocker is offline Stocker  United States
Separate relay, coil in series with the resistor, relay kills the +12?
Jesus loves you.
Old 2nd March 2005, 04:57 AM   #16
rth's Avatar
For all practical purposes the 12v is off... think about all the wall warts in your house that never get turned off.
Plausible, though relay coils draw a bunch of current so you'd need a hefty (gigantic, actually) capacitor to account for this. I just wouldn't worry about it, grid power is cheap and those little guys use very little with no load
DC offset on turnoff dm2a Solid State 6 13th September 2007 09:38 PM
Phase Linear Turnoff Thump d3imlay Solid State 8 5th February 2005 08:03 PM
LM3875 comes 'back to life' after turnoff transient suppression Beggar Chip Amps 24 27th August 2004 06:55 PM
DC offset... On turnoff? JoeBob Chip Amps 2 7th August 2003 06:23 PM
Cooling an amp with poor cooling BAM Solid State 8 31st December 2001 05:40 AM
Page generated in 0.08936 seconds (73.62% PHP - 26.38% MySQL) with 10 queries
