Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Lighting and OHP any lighting ideas and ohp info
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 19th February 2005, 06:12 AM   #31
Man your quick! It's around 12ft or so away, but it does look darker in the pictures. I'll give it a flip around in a few, see what happens. I did play with the settings on the LCD, nothing improves the contrast problem with the colors, but it might just be a weakness in this setup. It's really ok with me, but if it could look better, then I should try. I remember looking at other peoples setups, and they looked alot brighter, so after a cleaning, and a flip of the fraynel(see if it helps), it might look alot better, if not, thats fine to. Thanks for (quick!) replys.
Old thought to be broken 17,000 lumen OHP: 10 bucks.
nView Spectra C: 70 bucks.
6ft tall games and tv?
Pricele....
well, 80 bucks.....
(macrovision: PRICELESS *insert mad face here*)
Old 19th February 2005, 07:33 AM   #32
I flipped the lens, and did not fix my blurring problem, which I still can't figure out.
But it DID make my blurry image TEN times sharper, so it must have been flipped the other way around? In some of my 2-D fighting games, it looks like I can see lines in certian parts, but I think that might have been there all along, with the blur hiding it. In anycase, I'll take the sharpness over the blurry anyday!
Looks alot better, and little brighter, but I still haven't fixed the light leakage on this baby, so thats going to help alot to.
Pricele....
well, 80 bucks.....
Old 26th February 2005, 07:52 AM   #33
Someone said something about the color index not being that good using these types of OHP's, and was wondering....
would a lexan UV filter help, or worsen the problem? Doesn't it improve your color index? And I would think that these things would be shooting out tons of UV's.....
Pricele....
well, 80 bucks.....
Old 26th February 2005, 01:27 PM   #34
tjh is offline tjh
I put a piece of Lexan XL from Home Depot ($5) in below the fresnels. Don't know how much UV comes out of these, but figured it would be worth the extra layer of heat protection. I don't know that much about optics but I think the only thing it would improve would be to cut down on UV, not the color index.
As far as halogen bulbs go, they are supposedly very yellow in color compared to a metal halide or some other types of bulbs.
Status:
6/12/06: Redesigning everything, finally putting in the Ushio S400DD.
Old 28th February 2005, 07:26 PM   #35
Ok, I'm an idiot....
Anyway, my old Apollo AI-1000 has a small turning knob on the side of it, I look inside, and nothing is connected to the knob, it's just turning in the inside with nothing on it. All my OHP has is the light bulb, it's small reflector, and the wiring, but at the top left of it, looking towards the reflection, there is a orange knob, that doesn't turn anything....
Whats supposed to be there? I don't see anything in this pic either
The inside of this apollo A1-1000 looks just like the inside of mine, except mine has orange wiring instead of the blue.
Pricele....
well, 80 bucks.....
Old 28th February 2005, 08:48 PM   #36
tjh is offline tjh
Any chance you could put up a pic of the orange knob your talking about? The only one I know of that is any use is the one on the lens to adjust it. There are 4 other ones that were attached to the side of mine on little brackets, I believe so that one could roll film or some other long sheet across, but I'm not sure.
Status:
Old 1st March 2005, 11:35 PM   #37
I think your right! (about the knob).
Now, I just posted in a thread about someone who wants more light from a 600watt bulb setup. And I was wondering, to make it brighter, and get the best use of the light these OHP's make, why not make some sort of custom reflector? My OHP has a little reflector, are their any ideas on how to get all the wasted light to go up?
something like aluminum wrap all around the bottom? I have no idea.
I'm guessing anything that would not reflect the light evenly would look messy and terrible, and I don't know what kind of stuff I could use.
That is, if it would even help the light output in the first place.
Bah, just wondering.
EDIT: I just noticed my reflector is rather old and dull looking. Wonder if I got a new reflector how much it would improve the light output.
Pricele....
well, 80 bucks.....
Old 2nd March 2005, 01:13 AM   #38
bodgy is offline bodgy
a condensor lens might help
i'd polish it first
Old 3rd March 2005, 03:24 AM   #39
You just posted in another thread that these bulbs really only have an output of 2000/3000 lumens, which makes sense, as it's not as bright as some of the setups I've seen.
I guess I now have to go the expensive metal halide route I was trying to avoid. 160 bucks for a cheap MH setup for a rig that cost 80 bucks.
Oh well. Guess I'll be doing that next year when I have the funds.
Pricele....
well, 80 bucks.....
Old 29th May 2005, 07:48 PM   #40
Send a message via AIM to tylerheatherly Send a message via MSN to tylerheatherly Send a message via Yahoo to tylerheatherly
Default Looking for pictures/scematics for the Apollo A1-1000
Hey, i was wondering if you had had any more pictures of the projectors guts or have any drawn scematics, as I took mine appart to put in another case and ended up with one extra wire.
Thanks for your help,
Tyler (about-blank@houston.rr.com)
Thread Tools
Misc. ST-bulb (coke-bottle shape) tubes (and two GT-bulb) FS GordonW Swap Meet 0 4th January 2008 04:14 PM
Cooling an amp with poor cooling BAM Solid State 8 31st December 2001 05:40 AM
Page generated in 0.19653392 seconds (85.00% PHP - 15.00% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
