Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Lighting and OHP any lighting ideas and ohp info
Old 21st January 2005, 06:56 AM   #1
slick69 is offline slick69  Australia
Unhappy Text backwards
I have searched every where cause I thought someone might have had this issue?I have finished building my projector OHP with a 5 and half screen from portable DVD with anticipation plugged it in for a test run and The text is back wards I have tried placing the panel every way imaginable to no avail.Its a 3M 920 projector with triplet lense.The text is actually backwards on the projector before it even hits the lens and mirror.If its flipped there is no image.
I was told if I run it through PC I could reverse the text but the reason I got this is the fact you can plug in straight to the monitor out on TV and have TV or DVD playback.Plus my computer doesnt have A/V outputs.
Am i doomed or maybe the rear pro option?
Please Help.
Old 21st January 2005, 08:42 AM   #2
im no expert, but you could probably bounce it off a few mirrors
Old 21st January 2005, 12:51 PM   #3
Clinton is offline Clinton  Canada
You should be able to flip the panel and get it to project. There must be a cable issue if you get no pic when you flip it. If that does not work (really should) then yes all you need to do isbounce the image off 1 mirror.
Clinton
Old 25th January 2005, 07:48 AM   #4
Guy Grotke's Avatar
Default mirror-image
If you use no mirror, then you should be able to read the screen text upside-down from the lamp side of the LCD. If you use one mirror above the LCD, then you should be able to read the screen text upside-down looking down from the front of the projector. If you use two mirrors, then it is the same as no mirrors, etc.
The LCD should be bidirectional. No image means something is getting unplugged.
Old 26th January 2005, 11:48 AM   #5
AAAAAAAGGGGGHHHHH! Problem solved must have had a dodgy ribbon all of sudden I managed to get the image right way round but in black and white.To much fiddling the no image I have killed the lcd. Just won a Keycorp K56h on Ebay hope this one is allright any one had Experience with one of these?
Old 26th January 2005, 12:38 PM   #6
Guy Grotke's Avatar
Default Don't give up yet!
You might have a bad cable, which you could replace for a few dollars. If it is an FFC (Flat Flex Cable), which looks like a printed circuit but on thick flexible plastic, then you might just have it in the socket so the contacts don't line up correctly. I had this problem with an FFC extender: All my colors were inverted, because there was a short or open in the cable-to-socket connection. I opened the socket, lined up the cable to go straight in, and then closed the socket. Works perfectly now!
So, what kind of cable is it? FFC or ribbon? How many conductors? What is the pitch spacing?
Old 31st January 2005, 05:26 AM   #7
Me2! is offline Me2!  Canada
Me2!'s Avatar
Default text backward
Turn the screen around and it should work. Im Joking! Maybe it's turn the other way? No thats not it. Watch it though a mirror on the other wall! Yeah! Getting warmer - having too much fun here.
Seriously, as long as the LCD didnt get cracked or something it should still work. Make sure your connections are good and that the PCBoard hasnt grounded out on something with the moves.
Good luck!
Old 21st February 2005, 05:16 PM   #8
Its been awhile cause i gave up after my last effort it was a ribbon by the way Guy so it went in the trash.I have been watching Ebay and trying to buy a projection panel to dodge this problem but they go for to much in my opinion Aus $80 upwards.Just won another portable DVD sucker for punishment haha bargain $20.I did notice when I had an image on the last one sometimes it would freeze is this the response time?That was running it through a DVD player.Also any tips on protecting the ribbon would be appreciated.
Cheers
Old 21st February 2005, 09:13 PM   #9
bodgy is offline bodgy  Australia-Aboriginal
did you really score a pertable dvd for $20?
if so, you are gods gift to ebay.
Old 22nd February 2005, 01:18 AM   #10
Yea $20 it is faulty though they sell heaps of them on there they seem to have display but not able to load disc which doesnt matter as I only want to use LCD an A/V out puts so you can watch TV,DVD etc
An interesting text about Dac and upsampling gaetan8888 Digital Source 1 28th October 2007 12:31 PM
Quad 405: Bernd Ludwig's new Mod text stefaan Solid State 1 24th February 2007 11:15 PM
Eagle: Inverted Text? Devil_H@ck Everything Else 2 27th August 2004 01:22 AM
CD-Text information where in subcode? capslock Digital Source 7 13th April 2004 09:15 AM
Page generated in 0.10101 seconds (80.96% PHP - 19.04% MySQL) with 10 queries
