| Lighting and OHP any lighting ideas and ohp info |
#61 |
cool, thats probably the most useful advice ive gotten on these forums
thanks
justin |
#62 |
A while back I was checking a lot of "found items" like mixing bowls and ladles, to make a reflector. I connected a 6 volt flashlight bulb with about 10 inches of solid copper wire, up to a battery holder with two 1.5 volt cells. When I throw the switch, the bulb lights up, but not too bright to look at.
To check a bowl with this tool, I put the bowl on a table, and then laid the battery & bulb assembly on some books next to the bowl, used some masking tape, etc., so the bulb is held at the center of curvature of the sphere. Then I would move my head around to see if the reflection of the filament came back to the filament. If necessary, I would adjust the position of the bulb slightly and then try again. If you can find a position for the bulb where the reflection is right behind the filament when viewed from all directions, then you have found a good spherical object. This is a good test, since this "reflection back to the light source" mode is exactly how you use a spherical reflector in a DIY projector. |
#63 |
Bodgy,
I thought you might repost the link using the http button... Ill try to anwer from the specs you show. No. The worst spec is the CRI of 65. This bulb will have a few colours that really spike and the rest will be very flat. It is possible that the spikes are at the 3 primary wavelengths of your lcd but that would be a real gamble. Better to go with a 90+ cri bulb. The 40mm arc wont be great either although if your lens and projector are BIG it wont be too bad. It really comes down to the angles. |
#64 |
I have a m58 ballast i got for $30 .. 250 watt..... it seems like all the bulbs i can find for it are rated at 65 CRI. Are there any bulbs for the M58 ballast that has a higher CRI that anyone knows about?
justin |
#65 | |
Now, if we were using the dual condensor lense way, we'd want to focus all the light into the first condensor to then have it distributed evenly by the second one throwing at the fresnal (which may even be optional depending on condesor quality.) With this, there will be no hotspots no matter what and the most-even distribution I think we will ever get. If I can find a large condesor around 8-10" diameter, (For under $50) I am going that route. And yes, chrome has even lower reflectance then stainless and aluminum. I wouldn't be surprised if you could get aluminum to shine over 70% with the right kind of work. |
#66 | ||
#67 | |
Let me lay this on the table, a Mercury Vapor lamp fits in our Metal Halide ballast socket and works perfectly WITH A SMALL arc gap! I am pretty sure they are all under 20mm. Take a look around and see if this would benefit you any more then a MH setup. |
#68 |
I just did some research, my 400watt MH ballast has a 4000-volt starting pulse and as far as I see (from other sources too) there is a 1:10 ratio on wattage to starting power with the MV/MH lights. HPS has a higher wattage starting pulse then any other does. (Didn't find exact numbers though.)
#69 | ||
DJ |
#70 |
I am not an expert with this stuff, being a noob an all, but what about glass rod, like people make glass ornaments out of, surrounding the arc, and then bent towards a collector point and then melted together. Would this form a good light source or would it be k rap?. The thought occured to whilst making a shop light display using fibre optic light guide, in which i had 1 light source, but many fibre optic strands. In my thoughts you would end up with a single point light source, but can light be `bent` like this sucessfully?. What about glass cut to shape on the back and mirrored to reflect all the light back, or a lens which would be possibly a good shape, and that was mirrored on the curved side?
www.teamevil.co.uk |
| Page generated in 0.12627 seconds (84.45% PHP - 15.55% MySQL) with 11 queries |
