Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Lighting and OHP any lighting ideas and ohp info
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 8th January 2005, 03:19 AM   #1
Talking How about a home-made OHP
I started with the MkIII plans and mod ed it - it started has a
MkIII - I ran into lots of problems - not MkIII problems,
but lack of time - lack of distance from the screen -ect -ect
I had to keep changing lens and stuff - I had a focus adjust
like the MkIII but with the mirror and lens the focus that was
good for the screen was inside the hole, and unusable -
it was in the middle of the thickness of the wood - also if
I moved it up some I would have to hang from the ceiling
- that was ok, but it would hang so low that I was not able
to sit under it - my old van seat is under it, and I sit on it
to watch movies - so lack of time and Ideas - I knew that
the OHP arm would allow me the hang it up higher and
have a better focus assembly at the cost of a little
keystone-ing
So the MkIII lost its head and became a OHP
thought I would share it with you all
Old 8th January 2005, 03:21 AM   #2
side view
Old 8th January 2005, 03:24 AM   #3
inside view with 2 walls removed
Old 8th January 2005, 03:31 AM   #4
side view with wall removed
It works well, and is brighter than my retro fitted OHPs were
I would have liked a real projector, but this works well
and the next thing I will work on is my PSONE projector
Thread Tools
Home-made RCA interconnects flyingtele Everything Else 15 8th July 2009 09:22 AM
home made tomtt Everything Else 3 9th March 2007 08:28 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 02:29 AM
Home made PCB's demons_wing Chip Amps 27 17th November 2005 01:12 PM
Home made capacitors baggystevo82 Parts 31 26th May 2004 02:19 AM
Page generated in 0.16818690 seconds (72.94% PHP - 27.06% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
