Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Lighting and OHP any lighting ideas and ohp info
Old 1st July 2004, 02:05 AM   #1
willie
Guest
Question Need help wiring ballast please.
I've got a 250 metal halide M58 ballast. I've never wired anything before, so I'd like a little advice from someone with a little more experience. I know I'll be running 120 Volts, but other than that I have no idea how to wire this thing. I am planning on wiring it to a standard three prong plug, and I have the ceramic lamp socket also.
I know the one wire marked "Lamp" obviously goes to one screw on the lamp socket, but then what? Please, someone break it down potato head style for me. Thanks!
Here's a picture of the ballast itself:
  Edit/Delete Message Reply With Quote
Old 1st July 2004, 02:06 AM   #2
willie
Guest
Default Wiring diagram
Here's a picture of the wiring diagram:
Old 1st July 2004, 02:38 AM   #3
Here’s your picture with the guide on it, I figured it would make it easier. If you have any questions Ill make sure to get back to you on them.
Old 1st July 2004, 03:59 AM   #4
willie
Guest
Thanks a million! That answered my question perfectly. I hadn't even noticed the screws on the lamp socket were different colors. You save me a lot of time. Thanks again!
Old 1st July 2004, 04:55 PM   #5
Not a problem, cant wait to see your projection.
Kevin
Old 7th July 2004, 12:27 AM   #6
willie
Guest
Well I tried that and it doesn't seem to be working. The ballast itself seems to get a little bit warm, but hardly noticeable. The bulb itself doesn't do anything. I'm thinking maybe the bulb is broken. It sounds like something is rattling around inside of it, but it doesn't look like anything is loose and there's nothing that I can see that's broken. Do all MH bulbs make that sound, or is mine broken?
Old 7th July 2004, 02:01 AM   #7
willie
Guest
Nevermind, I had it wired wrong. Your directions were perfect Khmann, thanks again. Man, that's one bright bulb!
Page generated in 0.08214 seconds (73.87% PHP - 26.13% MySQL) with 11 queries
