Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Lighting and OHP any lighting ideas and ohp info
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Closed Thread
Thread Tools
Old 11th November 2003, 09:03 PM   #1
mathias is offline mathias
mathias's Avatar
Lightbulb Build your own HID-Ballast
Like everybody else I started my projectordesign with a halogen bulb, but found out that it was too hot and didnīt give the light output I wanted. So I started looking for HID-bulbs. I found a lot of them in disco-equipmentshops, but to find a ballast, was much harder. So I figured out that a fluorescent-ballast works in the same way a hid-ballast works, you just need more powerful ones. I did a electronic simulation in the computer with parallel 36W ballasts and it gave right voltage and current for the lamp I was going to buy. So I bought a Philips cdm-t 150W bulb and tested my design and it works very well. The best part is that itīs very cheap only $25. I have used this ballastdesign now for 2 months and it still works very good.
Old 11th November 2003, 09:06 PM   #2
mathias's Avatar
Default picture
Picture of the ballast.
Old 11th November 2003, 09:29 PM   #3
ace3000_1's Avatar
Send a message via Yahoo to ace3000_1
Default mathis
huh i like this idea and yess the ballasts suck for trying to find one in europe, the trusty old fluro ballasts rock for reliability too and are small, how hot do they run in your setup? and what voltage is the output at the lamp socket? i must say a smart idea u got going there but time will tell if its corect, i supose in this way that u have it we could distripbute the ballasts around in an enclosure to make it smaller too.
Trev
Old 11th November 2003, 09:56 PM   #4
Send a message via MSN to 18wheeler
very interesting idea and great work!
do you have any design for 250W bulb or 110V power source? would be interested build a DIY ballast in USA
by the way, where did you get CDM-T for $25? the cheapest price I found in US is $44.
Old 11th November 2003, 10:17 PM   #5
Send a message via AIM to zx3chris
very good idea. just a few days ago i was toying with the idea of putting home made HID lights in my car, only the ballast is too expensive. I have a friend at a ford dealer who can get the HID car bulbs for only $7, but the ballast (per side) is $150 his cost very high -- perhaps some of those ballasts you have, running off of a cheapo inverter may do the trick -- even found this ballast for 12v applications, however i think id need 5 or more paralleled for the power/voltage for 2 head lamps. thanks for the info
-chris
Old 11th November 2003, 10:17 PM   #6
ace3000_1's Avatar
Default 18wheeler
heya bud i think he meant $25 for making the ballast, although i got my bulb cheap somthing like $30 and sockets i can get for like $5 thats a g12 socket, the ballast about the same as the bulb.
Trev
Old 11th November 2003, 10:34 PM   #7
oops. Then where did you get yours? bulb, socket and ballast? I am think of making a rear projector, which will have a smaller screen (60"), better light controll, so a 150W CDM-T sounds like a good choice.
Old 11th November 2003, 10:57 PM   #8
ace3000_1's Avatar
Default 18wheeler
yeah to me the 150w cdm-t is the perfect choice for the rear projection we are looking into, not much heat either and that bulb is a kick *** bulb for colour stability and lm per watt, this is the link i got my gear from , i rang them for prices they are a distributer but sell to the public, u may need to find a ballast in the usa though for your voltage but realy i think this idea of mathis is great so id give that a go. If u ring these guys get a pre paid phone card its cheaper.
http://www.internationallamps.co.uk/..._subindex.html
Trev
Old 12th November 2003, 03:02 PM   #9
mathias's Avatar
The ballast getīs pretty hot but thats normal. I havenīt measured the temp but I think my gets 60 + 20 (temp in the room) = 80 degrees, according to the ballast manufacturer.By the way, tw130 means that the winding in the ballast can run 130 degrees hot for 10 years.
Old 12th November 2003, 03:19 PM   #10
mathias's Avatar
If you want to be sure the ballast works and gives the right voltage and current, you can test it with 3 200W normal bulbs for 230 Volt, that is equal to a 96V 150W bulb. You can use this design for 250W hid bulbs, but you need other values on the ballasts and the voltage and current will be diffrent.
Closed Thread
Thread Tools
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Page generated in 0.29167199 seconds (37.03% PHP - 62.97% MySQL) with 11 queries
Copyright Đ1999-2009 diyAudio
