| Lighting and OHP any lighting ideas and ohp info |
#71 |
High Voltage spike in every half cycle ? Where does it come from ? You must shortcircuit the core ballast a little while to get a high voltage spike, this is the way the igniter work. The igniter stop working when the voltage drop across the bulb/fluorescentlight. When the igniter not is working, there are no other parts that can give a voltage spike. I have never read something about the need of a high voltage spike when the bulb is running, not yet anyway.
When the bulb was new the voltage was 96Volt and the current 1.6-1.7A and that seems right to me. I know that other discarge lamp will rise itīs running voltage when they get older, for instance HPS will rise itīs voltage with 170%. A oscilloscope would be nice ! |
#72 |
As I've said many times before, discharge lamps are very delicate, and misuse can cause them to explode. This includes incorrect current and voltage. Not to mention the fact that different ballasts may not be balanced leading current hogging and melt down. So I'm closing this thread.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 08:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 10:52 AM |
| Page generated in 0.07260 seconds (72.17% PHP - 27.83% MySQL) with 11 queries |
