Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Lighting and OHP any lighting ideas and ohp info
Closed Thread
Old 6th January 2004, 11:39 PM   #51
vimax is offline vimax  Romania
I was just wondering if I wanted to use a 250W lamp the total ballast power increases linearily proportional?
The ignitor would be the same I guess...
Old 8th January 2004, 04:41 PM   #52
mathias is offline mathias  Sweden
mathias's Avatar
I can´t test the 250W bulb design but I did a simulation, according to that, you can use six 36W ballasts and you should get around 250W, but there are two version of the HQI 250W bulb, one that runs on 100V and the other runs on 133V.
Try this:
HQI 250W 100V = six 36W ballasts.
HQI 250W 133V = four 30W and two 36W ballasts.
I haven´t tried this, the only way to know if it works is to measure the voltage and the current, the bulb gets. Ignit the bulb and let it warm up, measure the voltage and current, when the voltage reach 100 Volt (100V bulb) lock at current-meter, it should say 2.4-2.5A. If the voltage goes over 100 V or you get more than 2.5A ,turn it of, replace one 36W ballast with a 30W, do the test again.
Old 14th February 2005, 11:08 AM   #53
Default 12v hid ballast
hi,
anyone one can let me know how to DIY 12v hid ballast???
thanks
moot
Old 14th February 2005, 11:41 AM   #54
A 300W 12VDC to 120(230)VAC inverter May work but you still need the ballast inductor (transformer) for current limiting and the ignitor to turn on the bulb.
Old 14th February 2005, 11:49 AM   #55
nyman is offline nyman  Finland
Originally posted by mathias
Yes, Condensator is actually Capacitor, I´m sorry for my spelling. I know it´s hard to find a 18 uF / ~300V capacitor, but you don´t need it. But without it, your electricbill will be more expensive.
The capacitor only changes the the phase of the current. This don't affect your electricbill, as the wattage is still the same.
Old 16th February 2005, 08:22 PM   #56
Megaman is offline Megaman  Sweden
Originally posted by ace3000_1
quote:
has anyone seen MH ballast for less than $50?
ya they are easy to find in europe, typically $25 -$30 230v though
Where is that? I'v been looking around but found none that cheap.
Old 25th February 2005, 12:27 PM   #57
Rox is offline Rox  Spain
Rox's Avatar
do yo think guys it is posible to make an electronic ballast with those dimmers?
i mean without any ballast.
If you check the especs on the net about the electronic ballast, you´ll find they work at 20Khz-40Khz frecuency range, (i guess this is the trick to limit current) if we could make an square oscilator and add a power stage to it.... i don´t know.
What to you think?
It could be posible to modiffy a computer power suply????
Old 25th February 2005, 12:46 PM   #58
li_gangyi's Avatar
IR has a range of ICs that do dimming...u might wanna look into those...but I only know they do flourscent lamps...perhaps they could be modded to suit?
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 28th February 2005, 01:09 PM   #59
this looks like it will run hqi lamps
what exactly do i need to get a 250w output
i have a 250w ballast, but it is core and coil., can i use anything from it
Old 2nd March 2005, 02:11 AM   #60
Guy Grotke's Avatar
Default ballast with just highspeed switch
I don't think the lamp would stay lit. If you look at the voltage across a regular flourescent lamp with a scope, you will see a high voltage spike at the beginning of every half cycle. I think this is required to keep the gas inside the tube ionized. Then the voltage drops down to the regular level (169 or 338 volts P-P sine wave).
I'd bet the MH ballast does the very same thing. So then you couldn't duplicate it with just a fast switch. You would need an inductor or a flying capacitor circuit to get the higher voltage spike.
Closed Thread
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Page generated in 0.12045 seconds (79.11% PHP - 20.89% MySQL) with 11 queries
