Will this lamp work in my projector? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Lighting and OHP any lighting ideas and ohp info
Old 6th December 2011, 03:51 PM   #11
Bohanna is offline Bohanna  United States
Originally Posted by DonoMan View Post
What does it matter if a lamp says UHP or SHP, as long as it is DC? I'm sure the colors won't be the exact same between manufacturers, but can they really be THAT different?
Yes they are different. The Philips UHP is AC I beleive and the NSH and SHP are DC. The ballasts that drive them are different. I have seen the same Exact projector body with two different Ballasts for two different lamps.
The PLC sp10N has a 160 watt metal halide lamp that vents at the rear which I believe is the NSH -SHP type
The PLC xp10NA has the 150 watt UHP Lamp that is sealed and gets cooled by osmosis
This also might explain why the lamps you are trying are failing.
Bohanna
Old 6th December 2011, 05:09 PM   #12
Lamp on Left sanyo PLC-Sp20N 160 watt Metal Halide rear vented
Lamp on Right Sanyo xp10NA 150 watt Philips UHP sealed
Bohanna
Old 6th December 2011, 09:25 PM   #13
DonoMan is offline DonoMan  United States
Send a message via AIM to DonoMan
So I guess either I pay $700 for a Marantz lamp or this projector is useless... I'm not sure I'd consider this projector worth $700. It's too dim and only 720p. It matters very much with what I do - I want a 110" screen @ 7' for Forza 4. 1080p would be a significant upgrade over 720p anyway.
Now I'll have to see if I can sell the thing for super cheap...
But still, the lamp I linked... it says DC...
Old 7th December 2011, 12:59 AM   #14
This thing has confounded the hell out of me!!!! It seems like the people at Runco think their customers have litterly money to burn! 700.00 for a lamp is SOOOOOO freaking way over the top it Boggles the imagination!!! It also explains why these things sell for so cheap used!! Any buyer will worry if the thing is going to work and for how long!!!!!! Seriously!!!!!! It seems like they built an albatross. Maybe the guy who designed the Edsel had a hand in its design!!!!!!!!
Bohanna
Old 7th December 2011, 12:41 PM   #15
Let me know what you decide to do. If the price is right I may be interested in toying with this beast!!
Bohanna
Old 27th December 2011, 05:04 PM   #16
Just curious ?? did you ever find a replacement lamp for this projector??
Bohanna
Old 29th December 2011, 04:43 PM   #17
Nope. Haven't bothered. I've got the projector listed on Ebay with a million watchers (obviously not literally - but a pretty good amount) and no bids so far.
Old 29th December 2011, 05:46 PM   #18
Go here,,,, this may be a lamp that will work for you.
Bohanna
hxxps://www.interlight.biz/light-bulb/UHP-DC-200W-P22A
BTW Where in Mass are you located??
Old 29th December 2011, 05:53 PM   #19
That's what I was hoping, considering it is the lamp that I originally linked Do you think it's got enough of a chance of working that I should buy it? I really, really don't want to spend $150 if it turns out to be the wrong part. But there is not as much interest in this projector at the price I was hoping. Like I said, I am getting views/watchers but zero bids as of yet :/
I'm a little south of Worcester... are you in the area?
Old 29th December 2011, 07:14 PM   #20
This is the lamp that goes in the proxima 6850 that inputs air from the bottom and vents to the rear . I would call the people at the site and see if this is the exact same one they are selling. I would also look at where yours inputs air and see if the airpaths line up. As long as there is an airflow you shouldn't be conserned it there are no exact holes that line up. As long as there is airflow you should be good to go. FYI I have taken a vented front and sealed back UHP lamp and drilled out some of the rear cement so it can vent and it works fine.
Hope this Helps
Bohanna
BTW I am on the south shore in the Cohasset area.
Copyright 1999-2017 diyAudio
