Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > Lighting and OHP
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Lighting and OHP any lighting ideas and ohp info
Thread Tools
Old 29th December 2007, 04:21 AM   #11
N-Channel's Avatar
Send a message via AIM to N-Channel
Bohanna,
Thank You so Much! I might even kick fixing it to the front of the line of projects. Will advise when I meet with success.
Steve
Old 30th December 2007, 06:28 AM   #12
N-Channel's Avatar
Been playin' a bit in the service menu & here's what I found: There are over 200 parameters that can be adjusted. Items 11,12, & 13 are the R, G & B settings, respectively. No parameter listed for clearing up image. Tried adjusting them, but to go from settings of 001B, 001B, and 001C, respectively, to 00FF will take a long time (~256 steps x 3)!
I should clarify my problem a bit- I am not experiencing convergence problems, where the R, G & B images meet (or don't), I am experience a Ghost image shift 13 pixels to the left of the main image. The 13 pixel shift is uniform top to bottom, and left to right. Image is now almost unwatchable.
If my problem is more accurately referred to as ghosting, and not convergence, then are there other parameters in the service menu I should look at? Does anyone know of an on-line tutorial for the DP9200's Service Menu? Thanks!
Steve
Old 4th January 2008, 11:32 PM   #13
N-Channel's Avatar
Originally posted by Bohanna
sombody sent this to me and it helped . "The cure for this problem is to go into the service menu and change
the data numbers 11, 12, and 13 to a setting of 00FF in the data
window."
This worked for me on the ghosting - the part I had to figure out was getting into the service menu.
to get to the service menu hold down the Menu and Normal Bottons for a few seconds and it wiIl Pop up
Make sure to write down the values before changing any Numbers
Good Luck
Bohanna
Oh Baby! My projo is now working again! Bohanna, THX a big bunch! I was thinkin' that I'd have to do the 256 steps x 3 thingy, but instead of going forward from 001B, 001C, 001D, 001E, 001F, 0020, 0021......, since parameters #11, #12, and #13 were at 001B, why not just back them up to 0000, then 00FF? Well, I tried this and it worked! First came #13, made things a bit blurrier, then #12, image snapped right back into place, then #11, and image cleaned up entirely!
THANKS AGAIN Bohanna!
Old 5th January 2008, 12:09 AM   #14
Bohanna is offline Bohanna
You're Welcome
Bohanna
Now go Buy yourself a MyhD MDP-130 install it in a computer and you will have one Kick *** HD Home theatre!!
Not just a Big screen TV But a High def Large screen
Bohanna
Old 5th January 2008, 12:34 PM   #15
N-Channel's Avatar
Oh? How's that? No DVI or HDMI inputs on the projo's patch bay. Or, is this something the MDP-130 addresses?
THX again!
BTW, think it's time to change my avatar?
Old 5th January 2008, 01:25 PM   #16
the MDP-130 has it's own HID VGA output that connects to the VGA Monitor out in the Puter and to the VGA input on the Projector. I have an 8 foot High Def projectoin screen in My Living room that Blows away any body who has seen it. I got My card from ram electronics in NEw Jersy. If you buy from them ask then if they can drop the price a bit ( in My case they took about 10.00 off. since I have bought two of them so far. this set up is the Balls I didn;lt get the daughter Sound card BUt I may get it in the future. the unit has a nice remote thawt has all kinds of controlls on iut to make up for the Proximas lack opf a remote and it's basic controls Just set the Brightness to about 10 the contrast to about 60 the Blue to 34 the green to 30 and the red to 32 and you can control everything else through the MYHD remote
the oNly drawback is the turn on button for the 130 in the remote has same commane as the proxima so when you hit it you have to wait until the Power off Prompt on the projector goes away.
BTW if you don't have an Hi def cable connection in your area this unit finds the broadcase High def for free
also you can use your regualr video gear through the card INput it is really the Balls!!!
good Luck Bohanna
Old 12th March 2009, 02:15 AM   #17
232 is offline 232
232's Avatar
This solved my problem also, with a bit different settings, using 0024, 002b and 0013 from 11 to 13 respectively.
Old 13th March 2009, 07:07 PM   #18
232 is offline 232
232's Avatar
edit - All three parameters are now 002b.
Also, pressing [Power] once makes exit from the service menu.
Thread Tools
Simulators and convergence rtarbell Everything Else 6 15th June 2006 08:04 PM
Page generated in 0.09128904 seconds (85.77% PHP - 14.23% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
