Go Back   Home > Forums > > > >
Lighting and OHP any lighting ideas and ohp info
DIY replacement lamp for projector
Old 22nd December 2009, 01:12 AM   #71
mattystar is offline mattystar  Canada
O.k I will have to gp pick it up from my moms, but I will be sure to post pics. So what do you think about the light n reflectors.
Old 31st December 2009, 03:55 AM   #72
Gizmotech is offline Gizmotech  England
Can you not use your existing relector from your original lamp? HID Xenons are the next best thing although a bit dimmer on increased screen sizes.
Old 10th January 2010, 09:15 PM   #73
No, because I bought it without the bulb and reflector. Also I can't seem to find where to short it to get pass the bulb check. Hope these pics give you an idea.
Old 10th January 2010, 11:06 PM   #74
Default Philips LC4431
Hey again, I went at it some more and found the basalst and removed it. Found the 3 wires. In my case it seems to me typical to colour. Red 5v, Black ground, and Yellow standby. Now I know I have to short the 5v to ground with a 5v resistor, but what about the standby? Also I heard someone went to home depo and bought a work light and used that with its basalst. Worked great apparantly. I seem set but I thought it would be helpful for you guys.
Old 14th August 2010, 03:50 PM   #75
goodness is offline goodness
Hi All:
My projector is [SHARP XR-11XC]
1.
I try to link the Emitter pin and Collector pin together of the PHOTOCOUPLER (I think it's PC123Y) like picture 01.jpg, and it work!! It will not show "LAMP OFF" anymore! But......
It shows "Warming Up, Please Wait...", and after few minutes...it turn off! @.@|||
2.
There is two components outside the lamp housing in picture 02.jpg which might relate to "Warming up" sensing I guess.
The close-up pictures are 03.jpg and 04.jpg.
Does anyone knowes how to solve this situation?
PS: I am sorry for the poor english. T.T
Old 24th September 2010, 03:17 AM   #76
Pic 3 seems like a thermistor. If it is then it is likely to be a PTC type where the resistance increases with the temperature. I don't think that the thermistor has anything to do with the projector not staying on after shunting the photocoupler. It is purely temperature related. Pic 04, you may need to take it off and show it in more detail. Somehow I feel you may be shunting the incorrect photocoupler.
Old 24th September 2010, 04:26 PM   #77
Thank You Gizmotech.
You are right! I was wrong!
There is another PHOTOCOUPLER (PC123Y) somewhere else. It setting on a narrow space that i can't take picture. This one is the correct PHOTOCOUPLER! So my problem now is to put a suit lamp in. It's really diffical to find this suit lamp....I'm still searching for the lamp!
Did anyone have idea about a lamp bright enough and cheap enough and easy to use for the projector? If the lamp use 110V will be most convenient, because it need no adaptor.
Thank you again!
Old 16th November 2011, 12:31 PM   #78
sole is offline sole
Default manually reset counter 3m mp8020 projector
hello I have a 3m mp8020 projector lamp you changed but still jumping the red LED bulb drawing not reset the counter to zero've lost control, can be done manually or removing any cable? thanks
Old 18th August 2012, 10:02 PM   #79
bgynite is offline bgynite  United States
How did you defeat the thermal sensor? I am working with a dlp projector and I have this last sensor board to fool. I tried putting it next to different heat sources to get it to work and read the ohms of resistance at the right temp but so far I have not had any luck.
Flickr: CGIAnimated's Photostream
At room temp I measure 11 ohms of resistance and with the sensor on a cup of hot coffee, then near a candle. I got it down to 5 ohms but I could not get the projector to power up properly without the red temp light coming on.
there are 4 wires and Im not sure how i should go about splicing in a resistor to simulate the right temp.
DIY replacement lamp for projectorHide this!Advertise here!
Help - replacement lamp for Yamaha M-50 slowpat Solid State 2 7th October 2008 08:08 PM
Copyright ©1999-2017 diyAudio
