Instruments and Amps Everything that makes music, Especially including instrument amps.
Ampeg SVT-VR or SVT-CL Schematics
Old 11th March 2007, 10:20 PM   #1
mroovka is offline mroovka  Poland
Question Ampeg SVT-VR or SVT-CL Schematics
Hello everybody,
I'd like to build tube amplifier on my own and I had chosen Ampeg SVT, but have a problem with schematics:
On the Internet I can only find an old SVT schems (http://users.aol.com/bluemuse/ampeg.html -SVT preamp and SVT poweramp). that uses 12DW7, 12BH7, 12AX7 & 6C4 tubes in preamp and driver stage. This times it's very hard to find 12DW7 & 12BH7, even impossible in my country :/
Does anybody have the new schematics (with 2x12AX7+ 12AU7 in preamp and 12AX7 + 2x12AU7 in driver) or can just adjust the older schematics to use only 12AX7 & 12AU7 (and maybe EL34 in amp stage) against 12DW7, 12BH7 and 6C4?
I'll be enjoyed with every help
Peace
Old 12th March 2007, 07:11 PM   #2
Mikael Abdellah is offline Mikael Abdellah  Sweden
I haven't checked completely myself but this site has a lot of Ampeg schematics
http://www.drtube.com/guitamp.htm
Old 12th March 2007, 07:30 PM   #3
radtech is offline radtech  United States
I've got a VT-22 that if I remember correctly uses 12AX7A, 12AU7A, 6AN8A, 7027A and maybe one other common tube... none of the schematics I can find online now match it, I'm pretty sure I found one a few years back though.. I can try to hunt it down if you're interested.. it'll probably mean taking an old PC out of mothballs
Old 12th March 2007, 07:46 PM   #4
aletheian is offline aletheian  United States
aletheian's Avatar
You can adjust them for more comon tubes, but the 12bh7 and 12dw7 are still being manufactured in russia... AND right over your boarder in the Czech republic, so i don't see why you can't get those in Poland.
Heghlu'meH QaQ jajvam!
Old 13th March 2007, 03:37 AM   #5
gingertube is offline gingertube  Australia
The 12DW7 is simply 1 of 12AX7 triode section (pins 6,7 and 8) and 1 of 12AU7 triode section (pins 1, 2 and 3) stuffed into a single envelope. If you are building from scratch it should be easy to adapt.
Ian
Old 13th March 2007, 09:26 AM   #6
Default Weird triodes
I can not get any in polish interent shops. It is possible, that they product this tubes only for The States and another west countries and that why they are unreachable in polish suplliers.
aletheian & gingertube : Yes, I can adjust the circuit to the new tubes and I know that they are simply mix of two types, but I'm looking for the new schematics, also because It contains less tubes and it would be less complicated and cheaper to build.
So radtech if you can send it, I would be very interested with this VT22 schem.
Thanks for all replies.
I'm still looking for these schematics
Old 13th March 2007, 09:38 PM   #7
aletheian's Avatar
You have a VT22 that DOESN'T use a compactron? THAT i would like to see. those are rare as a dragon's tooth.
Old 13th March 2007, 09:46 PM   #8
aletheian's Avatar
Default Re: Ampeg SVT-VR or SVT-CL Schematics
Originally posted by mroovka
Hello everybody,
Peace
Ampeg will e mail you any schematic that you need. I have a schem for an SVT-3 pro left over from a repair job... if you need it, i can send it to you. it has a SS power amp, but the preamp is classic SVT, but without the 12DW7
Old 13th March 2007, 10:37 PM   #9
Default SVT-3 schematic
I also have this one, but svt-cl and svt-vr have 2 channels in preamp. I'd also like to know, how is driver in this amps designed.
I was looking for e-mail on Ampeg site, but I couldn't find it on the contact site. Today I found it on the support site. We will see what they think about giving these schematics.
Old 17th March 2007, 02:51 PM   #10
So I finally got around to digging the amp out, and it seems my memory of it was a bit faulty, it does inded have the 12DW7 tubes.
Here's what it's got:
1 - 12AX7A
1 - 6AN8A
1 - 6CG7
3 - 12DW7
4 - 7027A
So it's not what I thought, apparently I had remembered the 12DW7s as 12AU7s, but still, no compactron!
Ampeg SVT-VR or SVT-CL SchematicsHide this!Advertise here!
Any Ampeg SVT-II (non-pro) schematics??? spirus Instruments and Amps 15 30th May 2010 11:00 AM
Ampeg SVT-VR or SVT-CL Schematics mroovka Instruments and Amps 62 12th November 2009 12:51 PM
Ampeg BA-115 Schematics Wanted! Zero Cool Instruments and Amps 6 8th December 2008 11:55 PM
Ampeg VL-502 aman74 Instruments and Amps 1 4th June 2008 01:53 AM
