Instruments and Amps Everything that makes music, Especially including instrument amps.
really weird linear potentiometers that have a logarithmic response
Old 13th February 2007, 04:39 PM   #1
VvvvvV is offline VvvvvV  United Kingdom
Default really weird linear potentiometers that have a logarithmic response
I bought a bunch of linear potentiometers and I have measured them they look totally linear in all measurements, but when I attached them to a novation commercial circuit board and controlled a music program the response of the knob in the software was completely logarithmic started very slowly and went fast at the end...
that is really really weird because it means that the Novation circuit board uses logarithmic potentiometers that are converted into a linear signal which is just completely barmy. so when I attach a linear one it's converted to a logarithmic signal.
Why the hell would this insane thing happened that a manufacturer uses logarithmic potentiometers converted into a linear MIDI signal?
Old 15th February 2007, 11:58 AM   #2
Daveze is offline Daveze  Australia
Because sound pressure/volume is usually a log scale?
Signature Pending...
Old 17th February 2007, 08:33 PM   #3
yes but i'm plugging in a linear potentiometer into a linear MIDI controller and the results coming out of the MIDI controller is logarithmic compared to the original potentiometer.
Old 17th February 2007, 09:49 PM   #4
Nigel Goodwin is offline Nigel Goodwin  England
Obviously the original pot wasn't linear then, it was either log, anti-log, or some special custom pot (less likely).
Nigel Goodwin
Old 21st February 2007, 02:09 PM   #5
uhcmos is offline uhcmos  China
Banned
Send a message via MSN to uhcmos
thanks
Old 5th March 2007, 01:24 PM   #6
thanks for that
Old 5th March 2007, 06:12 PM   #7
R.I.P.
This does not follow at all, completely depends on the crcuit its connected to, /sreten.
Old 10th March 2007, 06:57 PM   #8
Albertb is offline Albertb  United Kingdom
It depends what impedance you are putting it in with. Not only the value but the shape of any pot can be altered by hanging other resistances around it. A resistor between the top or bottom and the wiper for example will have a very profound effect. Could be as simple as that!
You could check out its action very roughly out of the circuit with a DC source, (9v ish battery?), and a meter. Make sure that any impedances in the circuit around the pot are much larger than its own value to minimise their effect on it
Old 30th March 2007, 11:00 PM   #9
thank you for that excellent advice, I thought that all 10k potentiometers would be the same, other than the curve, perhaps the circuit is going around the potentiometer so I should try and isolate one for measurements, and I will try and figure out what's going on with the voltage and impedance- it sounds like it takes a lot of thinking
really weird linear potentiometers that have a logarithmic responseHide this!Advertise here!
Logarithmic Pot. instead of linear? suicida Parts 4 24th February 2009 12:04 AM
24mm Carbon Potentiometers Linear 100K 100pcs space-cake Swap Meet 0 22nd October 2008 06:10 PM
XY PAD/weird potentiometers to use instead of Fader Pots? VvvvvV Parts 2 8th August 2007 11:27 AM
Logarithmic potentiometers eeka chu Parts 3 31st December 2004 02:17 PM
Potentiometers log vs linear Doug Everything Else 12 30th May 2003 12:15 AM
Copyright ©1999-2017 diyAudio
