Instruments and Amps Everything that makes music, Especially including instrument amps.
6N1P or EF86 for bass guitar preamp?
Old 11th February 2007, 06:10 PM   #1
Mikael Abdellah is offline Mikael Abdellah  Sweden
Default 6N1P or EF86 for bass guitar preamp?
Hi again guys
I need some help to decide wether I should go for the 6N1P wich I am quite familiar with or the EF86 wich I have NEVER played with before. Right now I have a 6N1P connected to a BUF634 buffer. It sounds awesome, but gain could be a bit higher. I was thinking about using the EF86 i pentode mode.
Old 12th February 2007, 01:04 PM   #2
*bump*
Come on. Someone must have experiences with the EF86???
Old 12th February 2007, 06:54 PM   #3
Zibi is offline Zibi  Poland
http://www.google.com/search?q=ef86+...l&start=0&sa=N
Old 16th February 2007, 04:39 AM   #4
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
With EF86 (Russian version 6Ж32П ) you will get much more gain than with 6N1P (6Н1П ). Try 6N2P (6Н2П ) instead. All 3 of them sound excellent.
The Devil is not so terrible as his math model is!
Old 16th February 2007, 05:14 PM   #5
Sounds great, since I need more gain than I get with my 6N1P. I got my EF86's yesterday. I will start experimenting with one next week. I started on the chassis yesterday evening.
http://www.diyaudio.com/forums/showt...threadid=83819
Old 24th February 2007, 01:20 PM   #6
I just got the EF86 connected to my buffer on the bench. Now we're talking! The gain is just what I was looking for. I used the same RC filter as I assembled some time ago for my 6N1P. That gives me closer to 300VDC than the 250VDC for the 6N1P since the current draw is much lower. Also the heater current is lower wich pushes the heater voltage close to its limits at almost 6.9VAC. I will probably start soldering everything together in my new chassis some time pretty soon. I'll post a few more pics as the work continues.
Old 24th February 2007, 01:34 PM   #7
Default Variable bias?
What could a variable bias add sonically for me? Is ot worth it? I could fit a suitable rheostat from the cathode, but I am not sure what good it would do. Could someone pleas explan it simply to me?
Old 28th February 2007, 04:06 PM   #8
I am soldering my preamp together right now but i was wondering if its best to connect the shield to the cathode or directly to ground? Any ideas? When I use the 6N1P I always connect the shield directly to ground.
Old 28th February 2007, 04:45 PM   #9
Trout is offline Trout  United States
Trout's Avatar
The EF86 is very popular in Marshall style preamps. I know the guys over at 18W.com have several schematics posted in their library that utilize them. If memory serves there were several variations posted over the the AX84 website also.
The Clips of the 18W amps I have heard sounded very good especially if your into that heavy Marshall overdriven sound.
http://www.18watt.com/files/ef86_layout.jpg
I have seen little mention of the Russian version.
Trout
Old 1st March 2007, 08:08 AM   #10
I have connected everything except my VU meter and fired it up about 2 hours ago. It works!
A s*itload of gain just like I wanted. I have a bit of hum that I will try to erradicate, but the biggest problem now is "scratches" when I turn my potentiometers. I bought really cheap pots, but I realize it was a bad misstake. Where can I find very, VERY good potentiometers with 500k and 1M resistance?
6N1P or EF86 for bass guitar preamp?Hide this!Advertise here!
Making and onboard bass guitar preamp Skywalker83 Parts 8 17th October 2012 04:28 AM
bass guitar preamp billr Instruments and Amps 19 26th May 2012 03:36 PM
Bass guitar preamp zafira1981 Instruments and Amps 33 26th January 2010 02:02 AM
Hybrid bass/guitar preamp Mikael Abdellah Instruments and Amps 10 16th February 2007 10:16 AM
Ef86, 6n1p & 845pp seroton Tubes / Valves 3 15th May 2005 07:25 PM
Copyright ©1999-2017 diyAudio
