Instruments and Amps Everything that makes music, Especially including instrument amps.
6N1P or EF86 for bass guitar preamp?
Old 2nd March 2007, 12:14 PM   #11
Mikael Abdellah is offline Mikael Abdellah  Sweden
I have ordered Alpha and CTS potentiometers that should arrive in the middle of next week. I have decided to change all my internal signal wiring to a highly shielded cable that should reduce the hum a lot! I will post pictures as the work progresses.
Old 2nd March 2007, 02:53 PM   #12
Trout is offline Trout  United States
Trout's Avatar
Speaking of scratchy pots,
I generally buy Alpha's because I can get them fast and easy.
On more than 1 occasion, I have had freshly built guitar amps that appeared to have a scratchy pot on the Hi Bright channel.
If I turned/increased the pot REALLY slow it would not make any noise, If I turned it fast it sounded really dirty.
It turned out to not actually be the pot but actually the tube in the V1 position. I replaced the tube, Noise gone.
Be careful adding shielded leads, I would only add them 1 at a time and test between additions. I as well as others I know have experienced that in some cases they actually induce noise.
That has never really made a lot of sense to me, Yet it does happen.
Trout
Old 2nd March 2007, 03:10 PM   #13
Thank you for the tip! I will use this cable. I allready have it between my bass guitar and the preamp, so why not internally as well. I like the cable a lot, both estetically and sonically.
Old 6th March 2007, 06:07 PM   #14
I have received my new potentiometers today and it looks promising. I ordered both CTS and 24mm ALPHA, but does anyone know wich ones are the better of these 2? The CTS has a plastic shaft.
Old 10th March 2007, 09:01 AM   #15
The preamp is almost finished. At least the first stage of it. I chose the CTS potentiometers and the beautiful corona cable took care of most of the humm. There is a small amount of hum even with the HV switched of so I guess it's either from the heater supply or stray leakage from one of the, so far, not twisted AC leads. I will try and make a complete schematics later. I will also post some new pictures shortly. The only big thing left now is the VU meter. I still haven't decided how to build it but it will NOT be with 3914/3915 IC's.
6N1P or EF86 for bass guitar preamp?Hide this!Advertise here!
Making and onboard bass guitar preamp Skywalker83 Parts 8 17th October 2012 05:28 AM
bass guitar preamp billr Instruments and Amps 19 26th May 2012 04:36 PM
Bass guitar preamp zafira1981 Instruments and Amps 33 26th January 2010 03:02 AM
Hybrid bass/guitar preamp Mikael Abdellah Instruments and Amps 10 16th February 2007 11:16 AM
Ef86, 6n1p & 845pp seroton Tubes / Valves 3 15th May 2005 08:25 PM
