Instruments and Amps Everything that makes music, Especially including instrument amps.
Damaged Lcd Display Korg Electribe SX-1
Old 17th January 2007, 11:40 AM   #1
yekuku is offline yekuku  Europe
Default Damaged Lcd Display Korg Electribe SX-1
hi guys, i d appreciate some qualified help in this one.
just got my second-hand Korg Electribe SX-1 from ebay and i noticed that the Lcd Display does not work properly.
when previewing names/options on the display the 6th letter is always missing.
it seems that the pixels of the 6th column refuse to turn black in order to show the appropriate letter. plz check the attached picture.
does anybody have exprerience with fixing small lcd displays?
is there sth i can do in order to fix it?
i am not a professional technician but i have experience with audio related repairs. Unfortunatelly i dont know anything about LCD displays.
thanks
Old 17th January 2007, 05:29 PM   #2
Albertb is offline Albertb  United Kingdom
Like you I'm no expert at LCD display electronics, but if the entire letter is missing this could suggest something wrong with a commoned path, (assuming that the method of illuminating each pixel type block in the letter is to control one terminal and common the second with all of the other pixels in that letter.)
If that is the case it may very well be a manageable fix. Is there any evidence of anything contaminating the board or components. From what I understand LCDs are more electrostatic than anything else and any tiny current drain across tracks could affect their action.
Old 18th January 2007, 08:20 AM   #3
hi albertb and thank u very much for your input.
i took a very close look at the unit and realised that in fact it is not actually a letter missing from the 7th pixel block but the 2 last pixel from the 6th column and 4 first pixel from 7th column. plz check pic.
i thought that there could be a problem with the contact that is responsible for the 7th pixels block, but it seems that i am wrong.
i ll open up the unit ,i ll take some pics and i ll let u know.
thanx for reading guyz
Old 30th January 2007, 10:23 AM   #4
well, i opened up the unit and for my suprise the LCD display is broken plz check the pics
there is a small crack at the bottom right corner.
But it seems that no vital parts have been damaged.
i got this unit 2nd hand and i dont know if the display problem is due to the crack or due to sth else.
i checked the lcd display contacts and they seem to work ok .
any ideas?
if the broken display is the problem does anybody knows how can i replace it ?
thanx
Old 30th January 2007, 10:50 AM   #5
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I would imagine it's a Korg custom part, so you would have to source a replacement from them. As for repair, I suspect if you have checked for the obvious dry solder joints and suchlike, there is nothing else you can do. Contact Korg tech support.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 30th January 2007, 10:56 AM   #6
thanx for the input pinkmouse,
yes i ve checked for dry joints and suchlike but they seem to work ok.
i d like to have some ideas about this from experienced users before i order the replacement part.
just to make sure that the crack causes the problem.
in this pic it is shown clearly that the crack does not affect vital components. ( at least i think so...)
any ideas about this would be very much appreciated.
Old 30th January 2007, 11:05 AM   #7
pinkmouse's Avatar
Impossible to say. The crack may be related, it may not. Looking at the number of pins, (unless there are more hidden underneath), there are not enough for a matrixed display, so the display probably has an on board processor to translate serial or parallel data into pixels. If this has gone wrong, there is nothing you can do about it. Do you have a scope?
Old 30th January 2007, 11:39 AM   #8
Unfortunatelly not.
i dont have a clue about LCD displays, i am just an audio technician
Also i cant see any pins and how the display is connected to the board.
there are 2 rubber (?) rows ( the pink ones, up and down ) that hold the display and probably are responsible for the communication to the board.
here is a pic of the back side of the display.
thanx for your help.
Old 30th January 2007, 11:39 AM   #9
imix500 is offline imix500  United States
imix500's Avatar
That type of display has no on-board drivers/controllers, everything is external. The thin black stripe on the top and bottom- that is the conductive strip that transfers electrical signals from the pcb to the lcd. It's a bit of black magic going on there as the traces on the lcd glass can't be seen easily. The crack in the bottom corner is certainly breaking traces going into the lcd. Also, from the picture the conductive strip looks a little bent down from the breakage, this is probably enough to throw it out of allignment. The lcd is probably not repairable, but certainly replacable.
Old 30th January 2007, 11:42 AM   #10
pinkmouse's Avatar
That makes sense. Well spotted.
Damaged Lcd Display Korg Electribe SX-1Hide this!Advertise here!
Need circuit schematics for Korg MR-1000 gentlevoice Digital Source 4 23rd September 2014 12:40 AM
2 X PIONEER CDJ-1000 MK3 PLAYER, Korg M3 88-Key Workstation / Sampler,Yamaha Korg holocoast Vendor's Bazaar 0 22nd August 2009 07:03 AM
tapping into keyboard of Korg Polysix mashaffer Instruments and Amps 0 5th October 2008 01:06 AM
Just ordered a Korg EMX-1 MikeHunt79 Tubes / Valves 5 19th May 2008 08:34 PM
Micro KORG SYNTH and Zoom Recorder kaybee Instruments and Amps 0 16th November 2006 06:33 AM
Copyright ©1999-2017 diyAudio
