Instruments and Amps Everything that makes music, Especially including instrument amps.
Guitar Amp buzzes off of power inverter, will this filter work?
Old 3rd November 2006, 06:19 AM   #1
silentblackhat is offline silentblackhat  United States
Send a message via AIM to silentblackhat
Default Guitar Amp buzzes off of power inverter, will this filter work?
I just put a 700 watt power inverter in my car(its a modified sine wave inverter so i know its not 100% clean power). When i went to hook my guitar amp to it(the car isnt running so theres no engine noise in play). I am guessing that this buzzing is because of the inverter not putting out 100% clean power. I know that the amp is DC power instead of 120V AC. So i am wondering if I put DC power noise filters(consists of 2 caps and the inductor) on those power wires, if it will stop the bussing sound. The picture is below of the blue wire pointing to the set of wires that carry the DC current.
This is an Ibanez TB25R Guitar Amp.
Any help would be appreciated.
Old 3rd November 2006, 07:40 AM   #2
I am just wondering if I need to get a true sine wave inverter or if i could get thosefilters to work for me. I have the picture of a true sine wave compared to a modified sine wave from an inverter. I see that the filters might be able to help quiet the amp since the inductor would smooth out the 'edges' of the modified sine wave.
Old 3rd November 2006, 01:45 PM   #3
clem_o is offline clem_o  Philippines
Take a look at your figure - the notice how the modified sine wave doesn't have the same PEAK voltage as the real sine wave. Filtering the modified sine so that it becomes a "clean" sine wave, if even close to successful, will result in an undervoltage for your amp - it will probably work, but don't expect full power from the amp...
Cheers
Old 3rd November 2006, 03:13 PM   #4
would I be able to just connect the 2 red wires together so i would only have to get 2 filters instead of 3?
Old 4th November 2006, 11:12 AM   #5
Howdy,
That certainly made me have a closer look...
The wires you are referring to are the output of the transformer inside your amplifier. The output of the transformer is AC, not DC. You can't use a DC filter there.
Cheers
Old 4th November 2006, 08:19 PM   #6
doesnt the amp run off of DC tho? would an A/C filter work there?
I am going to get a true sine wave inverter (later on tho, i have to save up for one, ill maybe get one off of ebay)because i think thats the problem where the voltage drops to zero for a period of time and then goes the other direction. would a true sine wave inverter solve my problem with the buzzing?
Old 5th November 2006, 08:18 AM   #7
Hi -
After the transformer, there are two bridge rectifiers (the two black squares in your first picture, right near the wires of the transformer where it enters the PCB). The output of those two bridge rectifiers would be DC.
If you do get a TRUE sine-wave inverter, yes, it would solve the problem.
Be wary though, I've seen claims to being 'true' sine wave, but the output waveform from the unit I tested looked pretty much like a modified sine you posted...
Cheers!
Old 5th November 2006, 03:55 PM   #8
so getting a cheap one off of ebay probably wont be a true sine wave? This is the one I was thinking of getting off of ebay.(link below)
http://www.powerbright.com/aps300.html
Old 6th November 2006, 12:21 AM   #9
It *looks* promising - there's a distortion spec of 4% on the manual. If that spec is true, it should be ok!
Cheers
Old 6th November 2006, 04:15 AM   #10
alright ill probably order it soon then. I will take it up to my local highschool(i graduated 3 years ago tho) because I know the physics teacher there so he would be able to use the osciliscope to test the wave form out. thanks for the help
Guitar Amp buzzes off of power inverter, will this filter work?Hide this!Advertise here!
About a PWM power inverter gaetan8888 Power Supplies 7 30th May 2012 06:15 PM
How can I filter out an inverter for less noises gaetan8888 Power Supplies 45 5th January 2009 05:52 PM
Antiparallel diodes as power line filter : how do they work ?? ygg-it Parts 17 6th July 2008 12:32 PM
Antiparallel diodes as power line filter : how do they work ?? ygg-it Solid State 2 4th July 2008 08:04 AM
power inverter Kelloggrice Parts 1 8th June 2007 08:44 PM
