Instruments and Amps Everything that makes music, Especially including instrument amps.
dod 490phaser
dod 490phaser
Old 23rd October 2006, 07:55 PM   #1
vicelord is offline vicelord  Romania
Default dod 490phaser
Hy there i just recived a dod 490paser and it doesent work....
I replace the battery cheched the cables...still nothing....
i opened it and doesnt look like somthing is burned...
What can i do please help
Old 23rd October 2006, 08:53 PM   #2
Optical is offline Optical  New Zealand
post a pic of the circuit board if you can, we might be able to suss out what burned and why from there..
Old 24th October 2006, 10:35 AM   #3
Click the image to open in full size. face
Click the image to open in full size. back
i thinck they are misswiered but dont know for shure
Old 24th October 2006, 03:34 PM   #4
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
dod 490phaser
Looks like one red wire is not soldered. Does it go from the battery? And looks like it has to be soldered right near the corner of the PCB.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 24th October 2006, 03:57 PM   #5
i know that it brocked when i putted back the circuit in the box...
Even with that wire right conected it stell doesnt work
Old 24th October 2006, 04:07 PM   #6
Wavebourn's Avatar
dod 490phaser
You need a voltmeter to go a little bit further.
Solder the wire back, connect the battery, insert in-out jacks, and trace the power voltage following wires from the battery to the board. Check if you connected properly input and output jacks.
Power switch in pedals very often is located inside of one of jack sockets, so when you connect your pedal, it is powered on; when you disconnect, it is off.
Check if power (9V) goes from the barrety to the board, a first.
Old 24th October 2006, 05:04 PM   #7
i measured...
i puted the red wire from the voltmeter to the hot wire on the board it shoed me 3v....
but when i putted the both wires from the voltmeter on there places it shoed me 0...
dont know if you understand
Old 24th October 2006, 05:45 PM   #8
Wavebourn's Avatar
dod 490phaser
i measured...
Try a new battery, it must be 9V. Also, check if a power switch "supposedly on one of jack sockets) is on when you plug your guitar and amp jacks.
Old 24th October 2006, 05:46 PM   #9
the battery i just recharged...
i dont get any sound at all from this box
Old 24th October 2006, 06:21 PM   #10
Wavebourn's Avatar
dod 490phaser
Did you check voltages after recharging your battery?
If the voltage drops down to the 3 volt either your battery is dead, or you must see some smoke going from your PCB.
dod 490phaserHide this!Advertise here!
