Instruments and Amps Everything that makes music, Especially including instrument amps.
DIY guitar amplifier cabinet
Old 10th December 2002, 05:40 PM   #1
Gabster is offline Gabster  Canada
Gabster's Avatar
Default DIY guitar amplifier cabinet
I was looking at some 4x12" marshall cabinets recently and I realized how simply they are built. Furthermore, I consider that bolting 4 speakers into a square box shouldn't give the best audio performances.
Considering Celestion's speaker frequency range (about 75Hz-5kHz), the air column should be more than a meter long.
Therefore, my goal is to build a 1x12" (maybe 2x12") cabinet for my 100W combo marshall. I'm new to loudspeaker building and I would need someone to set my on track. What should I read? What software should I use? etc.
best regards,
Gabriel
Old 10th December 2002, 06:40 PM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Hi Gabriel
Guitar speakers are not designed to give a flat even response, and if they do so it's purely accidental!
Guitar is all about tone, and this is achieved by drastic EQing, peaky speakers, amp overdrive and cone breakup, all anathema to Hi-Fi.
Thus there is no real software that can be used to calculate this, it is all a matter of doing things by ear.
Yes, Marshall cabs are simple, but they have been the sound of rock for over 30 years, and if that is the sound you are after, then just clone one, and this will work well with your idea of a 2x12" cab. Other than that, most smaller combo amps use open backed cabs, so if you prefer the sound of a Fender Twin, for instance, thats the way you should be going!
You will find that most good music stores will supply replacement speakers for any of the reputable makes of amp, as guitarists have a habit of blowing them up, so any copy you make could use origional speakers as well, ( although this may be more expensive than rolling your own)
So, go out and listen to guitar amps and boxes you like, take some seruptitious measurements of your favorite, and make a clone
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 11th December 2002, 12:34 AM   #3
Gabster's Avatar
Excellent reply, thanks.
Old 11th December 2002, 01:50 AM   #4
pinkmouse's Avatar
No problem
Old 9th January 2003, 12:15 AM   #5
tmc is offline tmc
tmc's Avatar
hi,,,,,,,,,
I'm also a guitarist that uses combo amps ( two in my stage rig)
And also was caught in the quandry over adding a 4x12 into the mix, mainly to cut down the feedback from the microphones due to the open back combos......( but then i remembered lugging those monsters around !!!!!!!!!!) (UGH!)
I finally decided to measure the cabinet space of the combo and build a non ported copy....it also can be used to elevate your existing combo,,,,(well there are several ways to use them )
Any way, hope you figure things out....as usual in the music arena there are a vast array of choices..........
Good luck!
taxes are for corporations
Old 9th January 2003, 01:34 AM   #6
JBL is offline JBL  Canada
JBL's Avatar
Send a message via ICQ to JBL
Just one point you will generaly want to make open backed cabinet. Thsi is to prevented peaky bass respons wich make guitar sound weird.
Althought that some sealed configuration could sound good but...
And thus the best configuration is actually bolting 4 speaker in a box.
Jonathan Blanchard (J.Bl.)
---Nothing is impossible---
Old 9th January 2003, 01:38 AM   #7
pinkmouse's Avatar
Not a fan of the Marshall Rawwwk sound then JBL?
Old 9th January 2003, 02:27 AM   #8
JBL's Avatar
I'm not a guitar player but being with them all the time you get to know stuff(especially when your in diy audio).
So no i'm not really a fan of marshall sound. But some marshall stuff sound good.
DIY guitar amplifier cabinetHide this!Advertise here!
material to cover guitar amplifier cabinet winner Instruments and Amps 6 24th March 2009 06:39 AM
bass guitar cabinet babagau Multi-Way 6 2nd September 2008 11:16 AM
guitar cabinet pinky78 Instruments and Amps 1 10th November 2006 07:53 AM
Building guitar cabinet- help? otokomae Instruments and Amps 8 20th October 2005 08:41 PM
Guitar Cabinet sub_urban Instruments and Amps 2 1st September 2005 05:32 PM
Copyright ©1999-2017 diyAudio
