converting PA head to 1/4' guitar input
I have a old Bogen K15 PA amp that I've partially converted for use as a guitar amp. I have a K10 that sounds awesome. I bought that was already done, and thought I could copy the mod. (It didn't work) I've installed the jack, used one side of the mic input, and have WAY too much level, and it's quite dark sounding. If anyone can tell me what I should do to convert this correctly, please help.
Im not familiar with those amps, but the dark sound will most likely be caused by having the wrong input impeadance, a guitar needs ~1Mohm - a mic is much much less.
The gain can be reduced depending on the mic preamp.
if you can find a schematic it would help greatly.
Does your amp have RCA jack inputs? Specifically, a mag-phono input? I recently got a Bogen M60A that I'm going to be doing a full conversion with, I was playing it through the amp simply by rigging an adapter to plug into the mag-phono input. If your amp has RCA jacks, try splicing into one of those instead of the mic and see what happens.
I'm not familiar with the K15. I know what they look like and I'm pretty sure thay were made in the late 1950s but that's about it.
tonemonster said:
Thank you for the quick response to my posting. I have a schematic, but have recently moved and can't locate it. Are there certain (standard?) steps to follow when doing this? Would a couple of pics be of amy use?
Thanks.
ok, ive found a schematic online, it looks to be hosted personally so i'd download a copy asap. http://www.flickerdown.com/forsale/k-15.pdf
im not that good at redesigning valve gear, but lot's of people on this board are. someone will point you in the right direction..
Actually as has been suggested, the phono input bypasses the input stage without additional filtering, you could try using that as your input first. the gain might be ok, but the input impedence is a a little too low, so you might notice slight a loss of highs again..
Wow, that's set up way different than my Bogen. My phono inputs actually feed into the first preamp stage, and I have "aux" RCA jacks that are set up similar to that.
I bet you'd get some more people's opinons if you posted this in the tube section on this forum.
-Darren
Make your input like the attached schematic. Best to have a shorting jack. Also, you could make "bright" and normal channels like many guitar amps by adding the cap shown to one of the volume controls.
Me 2
I just hooked up the K10 I bought on ebay and wow, lot'sa gain for just one preamp before the PI.
I am also looking for a schematic, and any hints on drilling out the rivets to replace tube sockets, etc.
I'm good with schematics, wiring, testing, troubleshooting, a little week on metal shop stuff.
Peace,
Rico
rivets
are easy; sharp chisel, grind off, or drill are your only options.
Suggest drilling-pick a very sharp drill, size about 1/2 way between
outer edge of dimple and edge of rivet-that way, no damage to sheet metal or socket. Large drill motor, SLOW turning speed(as slow as
possible, as vertical as possible:D) voila! Clean up the odd bits and
you are done!
