$5 mic pre
Hey all, I have been reading about this $5 mic pre online.
http://www.record-producer.com/learn.cfm?a=3062
and then here http://www.record-producer.com/learn.cfm?a=3071
and finally here http://www.record-producer.com/learn.cfm?a=3080
it costs more that $5 to build, but whatever, I am jonesing for a new project to experiment with!
I can't find the 47uf 60v caps for which the schematic calls. any suggestions for substitutes? here is the pdf data sheet and schematic towards the bottom.
I can't find those caps anywhere. Anyway, take a look and thanks everybody!
Interesting, although I cannot agree with the author about some of the component ommissions.
The protection diodes should be kept to clamp transients from 'hot plugging'. These can easily destroy the front end of the device. I would also add ferrite beads to choke off RFI and EMI.
The BB chip is not much different from the Analog Devices SSM2017/8 or the THAT1510/12. I have some AD pieces if you are interested. Also, check the app notes here http://www.thatcorp.com/icprod.html For other circuit delicacies.
60V isn't a normal capacitor rating, a normal voltage would be 63V, and you should find those easily. As already suggested, the voltage specified is a MINIMUM and not a requirement.
Thanks everyone! I figured that 60v wasn't a realistic cap rating, but I am a newb. Actually, I have a few more questions about the schematic, the gain pot at R7 (right?) should I eliminate R6 if I use a 10k pot, or should I use a 1k pot and keep R6? What about an inexpensive transformer on the output, is it necessary? The cable runs in my studio are merely 15ft.
I am kind of getting the hang of some of the basics now, and I'm getting really pumped!
Thanks again everyone!
Since the caps in question C1 and C2 are in the audio path, shouldn't they be poly or metalized poly? I found some on ce distribution for $13.80 (47uf 630v) and the price keeps getting higher as the ufs increase. It seems like mouser doesn't stock too many caps above 1uf. Am I going the right way, or am I freaking myself out? I want to find some non polarized caps for less that $13.80!
here is the schematic again INA217 mic pre
I just finnished Building a 2 Channel Full featured version of these Preamps......
I made it with the Protection Diodes and the DC Offset controll Loop and with Phantom Power and even added a Ballanced output stage so I get a ballanced output......
As for Input DC blocking Caps I just used some OK quality 100uF 63v electrolytics Bypassed with some 1uF and 0.1uF Mylar Caps which are the only caps in the Signal Path......
I am also use a regulated +/-15v Supply with +48v.......
This preamps sounds Great ......and Looks Good Too....
Cheers
