Instruments and Amps Everything that makes music, Especially including instrument amps.
4x12 Speaker cab wiring question
Old 2nd July 2005, 08:16 AM   #1
mytool4u is offline mytool4u  United States
Default 4x12 Speaker cab wiring question
I have been to every forum on the net and this is my last resort. I have been building a 4x12 cabinet for about a week now and am about to wire in the speakers. Every other forum gives me some complicated diagram with squiggly lines and arrows on it and then gets mad when I ask them to explain it, or they go of on a tangent about impedence. I have four 12", 16 ohm speakers that I want to put in the box. First of all is there any way I can wire them to get 8 ohms of output? Second can someone please tell me (as if they were talking to the dumbest person on the planet) how to wire the darn things together step by step? You guys are my last resort. From what I have read this forum is very helpful. Work your magic. Thanks
Rob
Old 2nd July 2005, 01:24 PM   #2
quasi is offline quasi  Australia
quasi's Avatar
Sorry there is no way to get 8 ohms from 4 x 16 ohm speakers and have all the speakers equally share the power.
You can wire them up for 4 ohms by connecting all the negative (black) terminals together and all the positive terminals together.
Any good amp should be able to drive into 4 ohms (check first though).
Cheers
Old 2nd July 2005, 05:35 PM   #3
When you say "all terminals together", does that mean that two wire ends will be soldered to the same terminal throughout the case? Sorry, but I did say I was the dumbest person on the planet when it came to wiring. So if I have this right it would go like this. Connect a wire to the pos terminal on the output jack, send that wire to the pos on the first speaker, solder a second wire to the pos on the first speaker and send it to the second speaker in the parallel, and so on until all four speakers are connected (so there would be more than one wire soldered to the same terminal, right?) Then do the same thing with the neg side. Is that correct?
Old 2nd July 2005, 09:03 PM   #4
Brion55 is offline Brion55  United States
Send a message via Yahoo to Brion55
This might help:
Old 2nd July 2005, 11:30 PM   #5
That diagram shows the parallel connection, but how are the connections that I have circled in your diagram made? Are they just spliced together?
Old 3rd July 2005, 01:34 AM   #6
quasi's Avatar
Originally posted by Brion55
This might help:
All correct. You can use the speaker terminals as the commoning point or you can wire back to a central connectin point. If I were you I would just wire directly to the speaker termnal point. This means that all speakers will have 2 wires per terminal except for one (the last one).
Cheers
Old 4th July 2005, 07:23 PM   #7
thedoctor is offline thedoctor  United States
Default Speaker wiring
Mytool, your posts on the other forums were answered quite well, I think, by those that know. What you changed is the impedence of your cab from your other forum's posts. In other word's, you found out you can't do it and changed forums cause you didn't like the answer. I think you are now getting the answer loud and clear. As for your opinion of yourself, it is yours so why fight it.
rookierob does it again!
Old 5th July 2005, 06:16 AM   #8
Default What's up Doc?
Actually, the other forums (that you are obviously a part of ) were condescending when it came to electronics. This forum was great! I said I knew nothing and meant it. All the others did was confuse me so I switched. I think that's just smart shopping. By the way, I think you should change your name from the doctor to Magnum PI. Get a life, and try to be helpful instead of facetious.
Old 5th July 2005, 09:48 PM   #9
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Is your objective 16 ohms or 4 ohms? Those are basically your choices. If you tell us that answer, I will walk you through the rest. What has been shown to you so far in this thread is 4 ohms.
Cal
planet10 needs your help:
Let's help Ruth and Dave
Old 5th July 2005, 11:14 PM   #10
Evan Robinson is offline Evan Robinson  United States
You could get 8ohms, but not by any combination of wiring all four together. You could wire two together in parallel (negatives tied together, positives tied together) and the other two in parallel, and then connect them to two separate amplifiers. But, it looks like you only want to use one amplifier, in which case, if you can find a way to wire them to get 8ohms, Georg Ohm would love to see it. So, you have these options:
1 amp:
16 ohms
4 ohms
6.4 ohms (amplifier sees that load, but subs will be unequally powered)
2 amps:
8 ohms each
Good luck.
4x12 Speaker cab wiring questionHide this!Advertise here!
Stereo/Mono 4x12" Marshall cabinet wiring tone1963 Instruments and Amps 5 5th January 2008 10:17 AM
Marshall 4x12 cab tareqx2 Instruments and Amps 22 18th September 2007 11:47 AM
wiring diagram for 4x12 guitar cab carlosy Multi-Way 1 2nd June 2006 03:31 AM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 11:10 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 07:03 AM
