Instruments and Amps Everything that makes music, Especially including instrument amps.
Dodgy amp needs repair
Old 15th April 2005, 01:56 PM   #1
sbattersby 115 is offline sbattersby 115  United Kingdom
Default Dodgy amp needs repair
Hey guys
I have a fender frontman 15watt amp thats giving way too much fuzz. I am not using any effects or pedals just playing the guitar straight through the amp. The fuzz and crackling drowns out most of the actual playing and I was wondering if anyone knew why or if I could fix it myself.
Old 16th April 2005, 12:40 AM   #2
Enzo is offline Enzo  United States
These amps are not complex, isolate the problem. COnnect the amp to a different speaker to see if hte speaker was blown. Headphones sound OK? Look for DC offset on the output pins of the op amps, a sign of failure. Got a scope to look at the waveform through the amp? COUld be a bad output amplifier chip.
And of course American amps must be upside down for proper operation in Austalia.
Old 16th April 2005, 12:54 AM   #3
mastertech is offline mastertech  Australia
Banned
Hi guys did you know that the fault could originate at the guiter electrical
part only and the amp could be fault free
sounds like bad input connections
Old 16th April 2005, 09:39 AM   #4
Well, that is certainly true.
Old 22nd April 2005, 08:53 PM   #5
thedoctor is offline thedoctor  United States
Default Fender fuzz
Enzo got the first test perfect. Try the headphone jack. If it sounds good with headphones, you know a lot more about the problem's probable cause.
Old 25th April 2005, 12:54 PM   #6
hey its me again. when i use headphones it sounds exactly the same. and when i plug in a mic it gives the same fuzz. When nothing is plugged in it doesn't sound just as bad but you hear it a bit. I have never repaired an amp or really anything much before so like keep it simple english please
Old 26th April 2005, 02:13 AM   #7
Centauri is offline Centauri  Australia
Most likely cause with these is output chip - it is the square plastic thing with 5 legs bolted to an aluminium bracket - type number TDA2050. These devices run hot, especially when playing at high volume, and the aluminium bracket / heatsink is not really big enough to keep the chip cool.
Cheers
Graeme
Old 27th April 2005, 10:42 AM   #8
Thanks for the advice guys. could it be something simple like the input jack? something tells me its the problem, if so would it be hard to repair?
Old 27th April 2005, 12:33 PM   #9
In your original post you said "fuzz" - do you mean buzz? Hum/buzz/crackling, especially when the input jack is moved, could mean cracked solder joints on the circuit board - very common in later Fenders.
Cheers
Graeme
Old 27th April 2005, 02:44 PM   #10
I could well be meaning buzz because I dont much know the difference Anyways it makes noise when it isn't supposed to like when a guitar is plugged in but you haven't played on it yet. Its strange because sometimes when you play on it the volume seems to increase itself and the pitch goes into an earpiercing scream. not nice
Dodgy amp needs repairHide this!Advertise here!
Analogmetric - Another HK Dodgy Dealer poynton Parts 20 12th November 2012 02:02 PM
dodgy PSU capacitor AndrewT Parts 15 8th July 2011 03:53 AM
CD With dodgy low frequencies ... mart34 Multi-Way 5 12th July 2009 05:01 AM
dodgy amp power supply obaka-san Parts 1 9th January 2008 10:12 AM
'Dodgy' tap water ash_dac The Lounge 14 8th March 2006 03:18 PM
Copyright ©1999-2017 diyAudio
