The toroid I bought weeks ago on ebay finally came.
I have questions about it. There's no markings on it except a sticker which I don't understand. How do I know it is the size that the seller said it was?
Also what wire is what?
It has
2 yellow
1 white
1 black
1 red
1 green
It has
2 yellow
1 white
1 black
1 red
1 green
It's suppose to be a 21VA + 21VA 225VAC ??? That's what the ebay ad ssaid I think. I believe I typed out the stats earlier.
It's aobut as wide as a softball. The two yellow wires are double insulated, the inner insulation is orange. And they are smaller wires, but not by much.
SirPoonga said:It has
2 yellow
1 white
1 black
1 red
1 green [/B]
If I understand this transformer correctly I'd assume the white, red, green correspond to the AC mains colors. Black would be ground. The two yellows would be the split voltage.
Or the green wire is the combined voltage and not the safety ground on the AC outlet.
Those two situations is what would seem logical to me.
I don't know about that transformer wiring you suggested. What are the gauges of the wire? This sounds like a Talema transformer I've seen where the yellow wires (lighter gauge) are the primary. The other wires make up the dual secondaries: white and black being one pair and red and green making the other. There was no earth on this particular transformer.
Without connecting to mains, check for continuity between each of the wires with a volt-ohm meter. The two primary wires should be continuous, as should each pair of the dual secondaries.
As for a preamp, something like the "Real McTube II" could be ideal. Check out the project details here:
http://www.firebottle.com/ampage/homebrew.cgi?cat=fx&sb=&so=hl&page=983211629RnqmzD4
Brian
Brian
balance said:I don't know about that transformer wiring you suggested. What are the gauges of the wire? This sounds like a Talema transformer I've seen where the yellow wires (lighter gauge) are the primary. The other wires make up the dual secondaries: white and black being one pair and red and green making the other. There was no earth on this particular transformer.
It is a talema. How do I wire it then?
http://img.photobucket.com/albums/v472/SirPoonga/tansformer.jpg
As far as I know, the two yellow wires are the primaries. The black and white make up one of the secondary pairs. The red and green make up the other secondary pair. But again, use a multimeter to check the continuity of each pair. And also make sure you use a fuse on the mains and even on the secondaries just to be sure.
Possibly someone else here can verify the wiring for this tranny. Anyone?
Remember we are talking potentially lethal voltages here, at least on the primary side, so be careful. If you are not confident wiring mains, maybe you could find someone to help you out, like a local electronics tech, or an EE student.
B
Those pairs have continuity.As far as I know, the two yellow wires are the primaries. The black and white make up one of the secondary pairs. The red and green make up the other secondary pair. But again, use a multimeter to check the continuity of each pair. And also make sure you use a fuse on the mains and even on the secondaries just to be sure.
I wish there was someone here in the middle of nowhere wisconsinRemember we are talking potentially lethal voltages here, at least on the primary side, so be careful. If you are not confident wiring mains, maybe you could find someone to help you out, like a local electronics tech, or an EE student.
Now comes the question of is there a way to make sure this has the specs as advertised?
http://geofex.com/Article_Folders/Power-supplies/powersup.htm
So if I understand this correctly, if the circuit requires the 28V (LM3886 circuits) I just use one secondary. Can use the other secondaries to power another circuit, say the 25V needed for the 360 preamp?
For the preamp portion, I have built this circuit
http://www.albertkreuzer.com/preamp.htm
and I am very happy with the results. I combined this circuit along with a single LM3886 in a 2 rack unit chassis (some power supply for TV studio satellite equipment). The power amp's +/- 35 volt (I assume 30 volts under load) rails are dropped down to +/- 16.4 volts via some resistors and zeners. resistor/zener derivation of the preamp supply voltage is used in almost all guitar/bass amplifiers. Specifically relating to this project, the source resistors for the first two FETs should be trim pots. I used some of those little 10 or 15 turn 10K ones with the little screw on them. biasing the FETS is very important for dynamic range. You can use almost any FET, jut you need to adjust the bias. You can change the overall tone of the amp, as well as the overdrive characteristics with just a readjustment of the bias point. The input voltage is not very critical, but it must be well filtered. The mid-shift on the EQ section is quite useful; although you can totally eliminate teh EQ section, since those "ultra high" and "ultra-low" controls go a long way to shaping your tone. The circuit is based upon an ampeg SVT. the sound is very clean, sparking, powerful, punchy, clear. It makes a great companion to my small tube amplifier, in terms of tone.
Here is a picture of mine:
http://www.nintendork.org/images/SVT/
The LM3886 provides around 50 or 60 watts of output, which along with my vented 1X12, allows me to play with my buddies just fine. A bigger power amp and speaker cabinet can easily be added for more power later. I built with about 80 to 90 percent recycled parts, and I was playing a game with myself to see how many different types and colors of recycled capacitors I could use!
here is annother post about bass amplifiers on ampage.net :
http://www.firebottle.com/fireforum/fireBB.cgi?cfg=ga&forum=gadc&thread=314190-000000.msg
The ESP project 27 preamplifier should also work well, it seems to be based upon a Fender style preamplifier.
If you plan to use that "FLipster" preamp, I would make sure to buffer the output before you send it off to anything (a JFET source follower, or a simple op-amp buffer would be fine), since the output looks pretty high-Z to me. fine for driving a guitar amp, bad for driving power amplifiers and other random equipment that have input Z's in the 10's of Kilohms. You should also be able to boost the voltage up somewhat. The voltage should only be limited by the ratings of the FETs you use and the capacitors. Be sure that the voltage is very well filtered, however.
This page has an interesting analysis of the bass guitar signal, along with yet annother preamplifier circuit for you to consider:
http://www.cafewalter.com/index.htm
I test a transformer by ohming out the windings. I should get readings from a few ohms to fractions of an ohm for a good winding. There should be infinite or many megaohms of resistance between different windings. Then I test it by powering it up with my combination isolation transformer and dim-bulb tester and check for the correct voltages on the outputs. The transformer shouldn't hum/buzz excessively nor should it heat up significantly without a load on it. But for a transformer that I bought and expect to be good, I'll just put it in the chassis along with the power socket, fuse, power switch, rectifiers, and filter caps and see if the power supply puts out the correct voltage before connecting the main amplifier circuitry to it.
I think I found out what my transformer actually is
4365-P1S2 is a number on the side, I searched that on google.
http://www.fairradio.com/lowvol.htm
Appears to be a dual 17V, not 21V like the ebay auction said.
so 17V X 1.414 is approx 25v. perfect for the 360 preamp. A little under the 28v for a lm3886. Hmmmm... Will have to power it up and test to make sure then.
Looks like I can start back on this project. Got a permanent job, therefore I have some money
One thing I need to do is create a preamp. I've been looking at this. I've been researching bass amps and preamps. It seems the bassics of a bass preamp contain:
Obviously input and output, and usually a passive and active input. Many have DI/XLR output, I don't need that. Some have line out, while that's cool and I could hook it up to my coputer I don't think I need that.
Then they all have some type of EQ/tone boosting/filtering. Most have 2,3,or 4 knob boosting. My hartke 2000 head has a 10 band EQ that you can turn on and off. It also has what it calls contour. From the sound of it, the two contour knobs are just low and high filter/boost.
FIY, the hartke 2000 has a tube and solid state preamp (each with own volume control so you can blend them, a compressor, 10 band EQ that you can turn on or off, two know contour control. Without the manual in front of me I am not sure where the compressor is in that chain, not sure if it is before or after the EQ.
For a DIY preamp that's all I'd be happy with, active and passive input, 3 band EQ, output to amp (with an effects send and receive between preamp and amp). If I want to use headphones I could just plug my headphone amp I built into the effects send.
I was wondering if there is a kit out there. I like the jfet bass amp that's out there because it looks simple enough to build. I think I'd prefer the 360 I linked earlier (did I link it earlier, I should have), but that looks a little more complicated.
Otherwise if I have to maek one my biggest problem is I don't know anything about EQ. I tried searching the internet but came up short. Found some theories but didn't really find anything on making my own. Also how does one handle active and passive inputs ?
I might make the preamp and power amp seperate (that way I can mix and match with my hartke).
I might start with the power amp and use my hartke 2000 as the preamp. I have to read the manual, I believe the effects send is after the EQ and such.
I think I will just get a kit from www.41hz.com. Probably the AMP2. Looking at their chart I will probably go with the
+/-45V 750VA 8 ohm bridged 1x600W Standard solution. I have a bunch of questions on this, will have to read their forum and/or email them.
I think right now for the power amp I'd rather have a kit. It doesn't cost that much more than buying all the componants myself and etching a pcb myself. Plus then if I screw up I know there are people with the exact same thing that could help
However, like others, maybe I will wait until the PSU board is available and then do the preamp first.
Just downloaded the manual for my amp. Grrr, the EQ is AFTER the effects. So I will have to go with the all or nothing route.
I have a friend with a Hartke 2000. it rocks. I'm not 100% sure, bu i think that the compressor is before the effects loop, and the EQ is after the effects loop. The tube/SS preamp stuff and the contour are before the efx loop. BTW, the tube in there does run with DC filaments and a real B+ voltage on it
The line out is essentially the same thing as the output of the preamp. In many amplifiers, the output of the preamp (line out) goes to the effects loop out, and the effects loop in goes straight to the power amp. A tuner output is just a signal taken somewhere early on (before alot of tone shaping things like EQ, tone controls or distorton), buffered, and sent to a jack.
For a active/passive input, the "passive" input is just the regular input into the preamp, the "active" input is just a -20 db pad on the input to prevent you from overdriving the first gain stage with a particularly hot active bass. The "passive" jack should have an input impedance of at least half a meg, 1 meg is common with some amplifiers going even higher. Go to schematicheaven.com and look at how an ordinary Fender amplifier has their two inputs jacks wired up with the You can simply omit the "active" input if you do not need it.
I might need active. Haven't decided yet. I'm a DIYer with everything I find (see http://free.hostdepartment.com/S/SirPoonga/yabcab.html)
I'm thinking of making my own bass using a warmoth neck. I've decided I am going 5 string, but not sure about active/passive pickups, etc... I found the body I want (http://mimf.com/library/moll_bass_final.gif) made out of some chestnut that was infected with worms. Will look cool
I don't think I will have an on board preamp, would be cool but that's getting overboard for something that just may not be that good .
Will probably make active/passive switchable. However, I like the look of the latest trend of having passive bass (no knobs). But that is difficult with two pickups. I'm thinking a neck humbucker and a bridge J pickup. I will probably just have the humbucker wired as dual coil, won't split the single coil. So that would leave me with 2 volume knobs and a tone. Will probably get wood knobs for that too. Actually, was thinking one concentric pot for volume, then maybe a push pull pot for tone and to toggle active/passive.
Probably won't happen for a year though.
Hello everybody!
SirPoonga, have you finsihed power- or preamp yet?
I'm also about to build a light weight bassguitar power amp (and preamp little bit later). Do you fellas think that Tracopower TIS series industrial powersuplies are suitable for audio use(t-amp)? I don't know pretty much anything about those parameters like EMI suppression, Ripple and noise, Line & Load regulation...
I'm planning to purchase AMP2 kit from www.41hz.com because it seems to be the most suitable for my use. I'd like to use switchingmode ps because of its light weight. Desired output could be (RMS) 2x200W/8ohm or 1x400W/8ohm or more bridged. Any advice given will please me a lot
ps. sorry my language, I'm at work and in a hurry Underlined: suitable switchingmode ps for 41hz AMP2?
I haven't been able to. Got a new job, had to move, etc... I haven't even thought about this in awhile
Won't probably get to it until fall or winter now. I have some other projects that "fell into my lap". Like someone gave me an asteroids machine that's working with no video. Trying to fix that.
I still want to do this but it isn't high priority now. Actually, getting a new bass is a little bit higher of priority. I am starting to out grow this one. As I expected I'd have issues with my current bass. It's a Squier P-bass. It served its purpose. It's a cheap bass that I bought to see if I was interested in playing bass. I am and this bass has its shortcomings. Thinking of getting a kit like a Carvin or Warmoth, I am a DIYer
- Live Sound
- Instruments and Amps
- Building a bass amp and speaker (cont...)
