Instruments and Amps Everything that makes music, Especially including instrument amps.
Easy DIY reverb?
Easy DIY reverb?
Old 1st July 2002, 02:21 AM   #1
fender4 is offline fender4  United States
Default Easy DIY reverb?
Hi. I would like to build a reverb unit to be used for vocals. It would be used in a live setting primarily, but it might find a place in the studio if it outputs a nice or unique sound.
For size considerations, I would like to stay away from spring-based units. I have several years experience with circuit building, so if you know of a design, pass it on.
Any ideas?! Thanks for your help. The audio knowledge on this board is impressive!
-fender4
Old 9th April 2017, 06:21 PM   #2
jfetter is offline jfetter  United States
jfetter's Avatar
if no spring then btdr 3, but try spring one more time , use a good hi-pass filter on line input and output.
here is a simple one but it uses a spring.
Old 9th April 2017, 07:31 PM   #3
jfetter's Avatar
and a 1960's discrete.
Old 10th April 2017, 06:45 AM   #4
thoglette is offline thoglette  Australia
thoglette's Avatar
Default Here's one for you to read
Originally Posted by fender4 View Post
Hi. I would like to build a reverb unit..., I would like to stay away from spring-based units.
Welcome back.
This DIY Reverb page on Hometracked lead me to this article from ETI magazine using the MN3011 BBD
As it's got plenty of "how it works" info you should be able to clone it with whatever BBD device you can get your hands onto.
Otherwise you're into ADC/CPU/DAC territory.
Old 10th April 2017, 08:23 AM   #5
Enzo is offline Enzo  United States
Hi, fender4 hasn't logged on since 2006.
Accutronics (Belton) makes a solid state reverb module for under $15. Needs +5, ground, in and out.
Old 18th April 2017, 07:26 AM   #6
m0b1liz3 is offline m0b1liz3  Australia
I always wondered if these could be integrated into old tube amps. I assume not because the old transformers wouldn't have those additional +5s right?
Old 18th April 2017, 08:57 AM   #7
They need little current, I am sure some sort of +5 could be cobbled from existing supplies.
Old 18th April 2017, 10:21 AM   #8
turk 182 is offline turk 182  Canada
Enzo would you have a link to share for that Accutronics module (did not see it on their site)
would a 5 volt supply from the heater section cause any grief?
Old 18th April 2017, 12:56 PM   #9
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
The Belton / Accutronics modules are available from AES (tubesand more.com). The data sheets are on their site. Select "reverb tanks" from their site menu, then search for "belton."
Here is the docs for the one I used.
Yes, you can use the 6.3 volt winding in a tube amp for power if it is already floating with a FWB. It might be possible to use a single half wave diode if one side of the heater winding is grounded, but I have not tried this.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 18th April 2017, 02:41 PM   #10
@Tubelab_com,
Is that you in the pic? You must pump alot of soldering iron :P
@Enzo,
Unless it is fairly brainless, I don't know if I would attempt cobbling a +5 from existing circuit unless the transformer had 5 volt taps.
Easy DIY reverb?Hide this!Advertise here!
want to buy reverb springs akis Parts 4 27th July 2009 07:28 PM
Reverb by 3 PT2399's??? yes... Ermac Digital Line Level 1 12th July 2009 07:26 AM
convolution reverb eStatic Everything Else 0 19th March 2008 03:21 PM
Crate reverb cqboling Instruments and Amps 1 10th April 2006 10:36 AM
DIY reverb? Spasticteapot Instruments and Amps 7 2nd April 2006 11:15 AM
